About Me
Stainless steel lettering and engine cover grilles, in stock and shipped from the UK
Re: About Me
Postby delorean12uk » Tue Feb 28, 2012 6:46 pm
fnzen wrote:Bandit,
you've got a smokey on your tail :lol:
Re: About Me
Postby willinot » Wed Feb 29, 2012 4:11 pm
Julian,
You probably dont have it still but I think you took an outline of my shifter plate at Ian and Shanes meet up not last year but the one before!
If not I can pull it of and send over but it will probably be a couple of weeks cos the car is not stored at home here.
Word of warning to anyone interested in one though. I love mine but keep in mind the gearbox needs to be adjusted properly otherwise it can be hard to select gears. At the minute I can select both 1st or 3rd in the slot for 1st as I need further adjustment and consequently it has marked the shifter stick where is hits the S/S of the gear locations. Also the S/S does not rust but the shifter stick is not S/S so it will rust (just enough to take the look of it a bit. Maybe consider a S/S slieve to go over the stick as well or do as I do and every so often run a bit of sandpaper up and down the stick.
Ive got the Shifter plate and ball so if you cant find the outline let me know.
Paul.
Paul
willinot
Re: About Me
Postby arranj » Mon Mar 23, 2015 12:19 am
All of Julian's parts are now listed on here: http://www.deloreanclub.uk/parts/delore ... parts.html - same fast service, but now with the added benefit of combined shipping with our other parts.
Return to Just Bandits
