Fuel Lines / Stainless Fuel Hoses - £219.99
Stainless steel lettering and engine cover grilles, in stock and shipped from the UK
Re: Fuel Lines - £215
Postby RobvdVeer » Thu Oct 16, 2014 2:04 pm
Done.I made it £190 with the £15 for shipping, right? Now, i believe AB had some spare injectors for me he wanted to combine the shipping if you guys meet up at the event this weekend.
Postby bandit » Thu Oct 16, 2014 2:09 pm
Yes, Rob, I can sort that. I have the lines in stock, so I will sort the injectors with AB & send the lot together after this weekends meet.
One of the many......
Postby RobvdVeer » Thu Oct 16, 2014 2:10 pm
two thumbs up
Postby bandit » Mon Oct 20, 2014 12:13 pm
Hi Rob, Your fuel lines & injectors have left today, you should see them in 3 or 4 days
Cheers Julian
Postby RobvdVeer » Mon Oct 20, 2014 12:22 pm
super
Postby RobvdVeer » Sat Nov 01, 2014 9:57 am
I'm not entirely sure which line goes where, could you help me out? I made it easier for you by including this numbered picture.
1) three of the longer
2) 5 about similar length
3) 1 really short
I also noticed that 3 of the #2's have the banjo set about 90 degrees from the other side. Is this intentional?
Thanks
Rob.
PS. Ok i found out one of the #2's that has a M10 banjo on one side, that one should be obvious.
Postby bandit » Sat Nov 01, 2014 7:58 pm
Hi Rob, I'm away this weekend, will have a look at mine when I get home & go throught it with you :)
Postby RobvdVeer » Sat Nov 01, 2014 8:15 pm
ok, no hurry there, still waiting on the copper washers anyway. I do have 10 spare bolts so i should be fine on that bit.
Re: Fuel Lines / Stainless Fuel Hoses - £219
Postby arranj » Fri Jun 26, 2015 12:18 pm
Just to clarify about these hoses, because some have asked. All of the small lines are clear coated, the 2 larger return and feed ones are bare braided stainless.
The clear coating can be any colour, e.g. black if requested (which will be made to order) - no difference in price.
For an example of a black coasting, see these brake lines: http://www.deloreanclub.uk/stainless-br ... lines.html
Postby RobvdVeer » Fri Jun 26, 2015 2:35 pm
I installed a set a few months back and they are great. It cleans up the engine bay very much as they look better and take up less space
Return to Just Bandits
