Vin 11753 Middle Eastern Car
Re: Vin 11753 Middle Eastern Car
Postby RobvdVeer » Thu Oct 02, 2014 9:20 am
ALEXAKOS wrote:
RobvdVeer wrote:bloody hell, that one runs better than mine. congrats
Maybe you need to remove the rear fascia then Rob :)
Haha good one. No it's the injector issue I'm sure. Ed said to me "Once you get new injectors, it going like a firetruck" (Dutch Expression for going very fast)
Postby ALEXAKOS » Thu Oct 02, 2014 9:30 am
Well Ed sure knows fire trucks;)
Postby RobvdVeer » Thu Oct 02, 2014 9:59 am
would you like to elaborate on that a bit?
Postby A Van » Thu Oct 02, 2014 5:01 pm
Been at Chris N today with the car, today was time to run the engine and check for any cooling or water pump issues
I cannot believe how well it starts and runs considering how long it's been stood for.
The engine has no head gasket problems and cools down lovely, even the fans work
Postby ALEXAKOS » Thu Oct 02, 2014 6:19 pm
A Van wrote:Been at Chris N today with the car, today was time to run the engine and check for any cooling or water pump issues
You are real good at rubbing it in! Hehehe
No really. Good for you. A smoothly running delorean is a blessing when you're on a restoration. Only aesthetics to tune then?
Postby A Van » Fri Oct 03, 2014 9:48 am
Intake off and into the valley......!!
Postby Admin-bloke » Fri Oct 03, 2014 10:19 am
Al, while you're at it check the bosch choose on the distributor and with the v pipe removed unscrew the thermo vac switch to check its operation. I'll check the forum a as I'm sure I've described how to test this before. It can be done by heating the end with the flame from a lighter and blowing through the central vac connection.
Also check that the thermistor is 10-12k ohm at 15-20 degrees as I've seen wrong ones fitted.
Keep it up
Postby A Van » Fri Oct 03, 2014 12:07 pm
Roger diddley
Postby A Van » Wed Feb 04, 2015 8:52 pm
Coming on now, all running stainless exhaust on
Filled autobox yesterday, and changed final drive oil, and the new governor, all seems ok with the wheels off the ground, waiting for a front hub carrier from Ed for the front wheel.
Hopefully be able to road test Friday then book in for MOT
Postby Admin-bloke » Wed Feb 04, 2015 9:00 pm
That's a nice looking garage lift! :thumbsup:
Return to Middle Eastern Cars
