- 82D82340-F700-4CB7-BE32-8DC8495BEC48.jpeg (2.75 MiB) Viewed 3935 times
Stuart Rees and myself got started on the car yesterday - getting it ready for MOT and then registered - as I mentioned on my earlier thread the handbrake did nothing - so that was the 1st job - Stuart instantly noticed the shoes were in the wrong way around so we replaced them with a new set from Aaron along with a new set of brake pads too - now I have a good handbrake ( 3 or 4 clicks ) just hope it gets it through the MOT - also fixed one of the marker lights and replaced both wipers so next job is find out why I have no lights ( they were working when we drove it onto the trailer in Dublin ) ?? And a oil and filter change plugs etc
One slightly strange thing we found when we took the top panels off the doors to see what was written inside - one could easily be seen and figured out it read - “ b shift - the date and some kind of signature but on the other door you could just about see the same writing but was sprayed over with a grey paint ??? Strange - also between the door and panel ( where the writing is ) a sheet of reflective foil insulation was inserted???
