VIN 5219
Re: VIN 5219
Postby andyd » Fri Apr 12, 2019 11:12 pm
POR-15 is good stuff. I used it with marine clean, hot water, and prep n ready as per instructions. Other coating systems are available! (Which are admittedly cheaper)
A
Re: VIN 5219
Postby InoX » Sat Apr 13, 2019 11:42 am
Hello.
I'd second that. Although it is time consuming stripping back the epoxy to where you're back to solid material. Prep's always the key.
InoX
Re: VIN 5219
Postby DMC1983 » Sat Apr 13, 2019 8:56 pm
Well im getting there. Its looking a lot better but still some way to go yet.
Deloreans.... where one job turns into multiple jobs :lol:
Re: VIN 5219
Postby DMC1983 » Wed Apr 17, 2019 1:02 pm
Well thats nasty. Good thing its going
Re: VIN 5219
Postby DMC1983 » Fri May 10, 2019 6:27 pm
Seriously, WTF was the previous owner on? Theyve soldered (rather poorly) wires into anywhere. Theyve also put different coloured wires together. So a green wire just turns into a grey wire for no reason. I literally have to follow the entire length of the wire. The pictures show where some of the crappy alarm wires are wired to.
Re: VIN 5219
Postby DMC1983 » Sat May 25, 2019 3:15 pm
The car is now running! Success!!
Got a leak at the crankshaft which may go after ive run the car a little longer but that seal is on the to do list.
Cat gets really hot way too quickly so i need to get a bypass till i decide to upgrade the exhaust system to stainless. Could just be an air leak somewhere so i will be changing the injectors and their seals and at the same time new spark plugs.
Tbh im really chuffed with myself that ive got the car started. A few connectors cleaned and changed all the relays and voila! Now need to get her running smoothly.
Thanks for all the advice given guys. Its been a real help.
Re: VIN 5219
Postby DMC1983 » Sat May 25, 2019 7:58 pm
Gotta find out why the car is overheating. Temp goes up to 250+ and the fans dont kick in. Fans do work when bypassed but not when connected to the otterstat
Re: VIN 5219
Postby mec » Sat May 25, 2019 8:04 pm
More than likely a new one is required, id reccoment the new screw in version which comes with its own new section of pipe available from arran at delorean go
Re: VIN 5219
Postby iudexmaximus » Mon May 27, 2019 10:07 am
DMC1983 wrote:Gotta find out why the car is overheating. Temp goes up to 250+ and the fans dont kick in. Fans do work when bypassed but not when connected to the otterstat
Is the engine really overheating or does the gauge tell you that the engine is overheating?
FYI: the water temperature sensor is located at the RH bank. A (hot) air bubble may get stucked at the sensor while circulating in the water and make it show an incredibly high temperature in the instrument cluster.
This happens because air has a much lower thermal inertia than water, therefore air gets hotter than water in the same amount of time.
So the gauge will tell you that engine is overheating, but the otterstat won't trigger the fans because the engine is not really overheating.
It has happened to me the first day I took it out from the box once driven home in 2009.
iudexmaximus
VIN #: 00878
Re: VIN 5219
Postby DMC1983 » Mon May 27, 2019 9:47 pm
Pretty sure the engine is overheating cos it gets hot. Ive cleaned the otterstat terminals and still the same (fans dont come on).
I bypassed the fans today and they appeared to do nothing. All the coolant pipes/rad are cold to the touch (i allowed the heat gauge to go no further than the 220 mark). So im wondering if theres now something wrong with the water pump. I need to invest in one of those laser thermometer things
I dont think i have a condenser either. Could that cause a problem. All i appear to have are these broken cables
