Servicing Items and Part Numbers
Re: Servicing Items and Part Numbers
Postby arranj » Tue Jul 22, 2014 10:42 pm
http://www.ebay.co.uk/itm/181362858431
MIL604 was the part number when matched to Tyson's Volvo, but I have no idea if I wrote that down right! Also we used OEF487 for years (Renault version)
Postby Chris Hawes » Thu Jul 24, 2014 7:31 am
Thanks for the input guys.
I hope the seller on the eBay link is wrong as the compatibility option reckons the leads won't fit a DeLorean...
Regards,
Chris Hawes
Chris Hawes
VIN #: Ex owner of 5255
Postby MikeWard » Sat Jul 26, 2014 10:51 am
Chris Hawes wrote:Thanks for the comprehensive list Mike.
I now have all the bits except for:-
HT Leads - PFV902576 (Volvo 260/760 series B28 Ignition Lead set)
None of the motor factors I went to recognised the above part number. Any more information available so I can help source the right set?
Which version of the B28 is the DeLorean as I think there were multiple variants of the B28???
http://www.partsforvolvosonline.com/pro ... ts_id=2576
I believe Mark (flux3d) used these on his car earlier this year with success.
Postby lukebrynycz » Fri Aug 01, 2014 4:25 pm
Excellent thread guys, nice one! :thumbsup: :dmcdoors:
lukebrynycz
Postby Chris Hawes » Mon Aug 11, 2014 9:44 pm
I took a punt on the set via the URL that Arran provided and despite the vendor's drop down saying that they aren't compatible they are the perfect length and now fitted. I've emailed the vendor so that they can 'correct' their drop down.
Thanks very much for the input guys, very, very helpful and saved a lot of time :thumbsup:
Regards,
Chris Hawes
Chris Hawes
Postby A Van » Thu Aug 28, 2014 9:58 pm
Thanks for the update Chris
Postby Chris Hawes » Fri Aug 29, 2014 5:53 pm
The original fuel filter has had to go back on to the car as the part number is wrong for the one earlier in the topic (it's doesn't fit).
I hope someone reads this far before ordering parts based on the earlier mentioned.
Otherwise as it stands at the moment all else is good :)
Regards,
Chris Hawes
Chris Hawes
Postby arranj » Fri Aug 29, 2014 6:16 pm
The Bosch filter no longer fits due to a redesign. We stocked a Comline version / I don't have that part number to hand but will on Monday.
Postby MikeWard » Fri Aug 29, 2014 6:59 pm
Chris, I discovered the same issue the other week, the Bosch filter has been redesigned and the thread is no longer built into the housing of the filter, it's a captive nut - result being, it's no longer suitable for the D and will leak if used.
As a replacement, I used the Mahle KL 204, I held off on posting up the part number as I wanted to do put a few miles on it first: http://www.opieoils.co.uk/p-60849-mahle ... saab-.aspx
The KL 36 will also work, however the KL 204 best matches the original filter (the KL 204 also comes with copper crush washers for the banjo bolt):
KL 204 Outlet:
KL 204 Inlet:
Postby A Van » Mon Sep 01, 2014 2:58 pm
Cooper Fiaam filter FT5203/ FIG7008 is ok
