by Dangermouse » Mon Nov 02, 2015 3:47 pm
Full specs:
Engine:
- 1995 Toyota Supra 2JZ-GTE 3.0 liter turbo charged inline 6 cylinder engine (400 horsepower at the wheels, 15 psi boost)
- Mini laptop for engine management system
- Late model USDM Toyota Supra Camshafts
- Stock bottom end with a rebuilt head
- 1995 Toyota 4Runner pressure plate
- Custom 6 puck fermatic clutch disc
- 9.5" Fidanza friction surface (newer model)
- Serpentine belt, Gatorback 4060747 or 6PK1897
- New seals
- New timing belt
- Turbo upgrade & boost gauge
- Water to air intercooler with front mounted heat exchanger
- Steel headgasket
- ARP head bolts
Transmission:
- Stock DeLorean transaxle
- Quaife limited slip differential
- Toby Peterson's shaft coupler
- Driveshaft shop custom 1000hp axles
- Wilwood 3/4" pull type slave cylinder (P/N 260-1333)
- Wilwood clutch master (P/N 260-6087)
EFI:
- 1995 6-speed JDM Toyota Supra ECU
- AEM F/IC-6 Piggyback EMS
- Digital RPM relay
- Bosch 044 fuel pump
Brakes:
- 11" vented and slotted brake rotors front and rear
- "Hi Spec Motorsport" 4 piston aluminum race brake calipers
- Stainless steel brake & clutch lines
- 4 pot brake conversion kit
Suspension & Wheels:
- DMCH springs
- upgraded gas shocks front and rear
- Toby Peterson's trailing arm bolts (Toby TABs)
- "Big Wheel" set from Martin Gutkowski (17" front and 18" rear wheels)
- Adjustable rear lower control arms
- Front lower control arm stiffener brackets
Fuel:
- Stainless AN-6 fuel lines
- Bosch 044 fuel pump (700 hp capable)
Cooling System:
- Three core brass radiator
- New water pump
- All silicone cooling hoses
- Dual fan fix
Misc:
- Chris Nicholson refinished stainless steel bodywork
- Restored interior
- Tinted windows
- Toyota Supra A/C compressor
- Alpine CD player/radio
- Digital door lock module
- Momo racing steering wheel
