'New' DeLoreans
Re: 'New' DeLoreans
Postby minispeedstar » Wed Dec 09, 2015 12:24 pm
Someone needs to come up with a quality fuel sender unit. One that doesn't give the actual reading till the following day after you've filled up!...
minispeedstar
Re: 'New' DeLoreans
Postby MikeWard » Wed Dec 09, 2015 12:49 pm
minispeedstar wrote:Someone needs to come up with a quality fuel sender unit. One that doesn't give the actual reading till the following day after you've filled up!...
They did, it's called 'Tankzilla' - no longer available. Essentially it was a saab fuel sender with a logic box to convert the signal.
Re: 'New' DeLoreans
Postby delorean12uk » Wed Dec 09, 2015 1:45 pm
MikeWard wrote:
arranj wrote:
minispeedstar wrote:Apart from the many parts they don't actually have new / available
yet.....
I reckon someone's got some flights to China booked ;)
Lesson 1 - stick to NOS parts where possible, or known quality replacements (i.e. the UK lower balljoint).
I would much rather pay a bit more for a decent part, than for some cheap piece of crap that doesn't perform the job as well as the original, and/or falls to bits within a short period of time.
This is the main issue that's been the problem of late, to make parts viable for a limited market they are having stuff reproduced at the cheapest price possible, and consequently they fail. If you read the sema document at the start of the thread it states :- The vehicles are required to meet current model year emissions standards. you wouldn't be able to do that on mechanical fuel injection system, WW and his side kick would have to invest heavily in an aftermarket fuel system that is compatible with the PRV or source another engine altogether, either way its got to be financially viable for them to do this
Re: 'New' DeLoreans
Postby A Van » Wed Dec 09, 2015 2:27 pm
Electric !
Re: 'New' DeLoreans
Postby delorean12uk » Wed Dec 09, 2015 4:50 pm
A Van wrote:Electric !
I thought they had already tried that???
Re: 'New' DeLoreans
Postby A Van » Wed Dec 09, 2015 6:13 pm
Only once
Re: 'New' DeLoreans
Postby mec » Wed Dec 09, 2015 8:46 pm
Re: 'New' DeLoreans
Postby Admin-bloke » Wed Dec 09, 2015 10:13 pm
I'd rather walk....and to me a "walk" is defined as that bit you do between the house and the car. .
Re: 'New' DeLoreans
Postby Dan 6511 » Wed Dec 09, 2015 10:22 pm
I went in the electric delorean when I visited DMCH years ago. I have to say it was VERY quick, also smooth and quiet. Not much use for the road trips though because of the limited range.
Re: 'New' DeLoreans
Postby A Van » Fri Dec 11, 2015 3:50 pm
Just spoke with James Espey today, everyone is really buzzing about this at DMCH
No news yet on drivetrains or specs etc
