200bhp rebuilt PRV engine/gearbox on eBay
Re: 200bhp rebuilt PRV engine/gearbox on eBay
Postby mnickels » Fri Sep 25, 2009 6:15 pm
The engine is now in the possession of the Delorean Club awaiting transport to me. Tyson and Al have worked hard today collecting and splitting the engine and gearbox. I owe them plenty of beer tokens for their help. Thanks guys
Postby tourettes tony » Fri Sep 25, 2009 6:58 pm
I met Al and tyson at pj's earlier and it looks good to me, especially the carbs :D TT
Postby mnickels » Fri Sep 25, 2009 7:03 pm
tourettes tony wrote:I met Al and tyson at pj's earlier and it looks good to me, especially the carbs :D TT
Good to see it has the TT seal of approval. Can't wait to see it in the flesh
Postby tourettes tony » Fri Sep 25, 2009 7:05 pm
I also think it has the delorean carrier, but dont quote me on it, and it has been rebuilt you can tell by looking TT
Postby mnickels » Fri Sep 25, 2009 7:09 pm
"SPECIFIC TUNING & IGNITION ETC. DETAILS OF THIS SET-UP"
- CYL HEADS
NB: NOT RACE TUNED - THIS IS A FAST ROAD STAGE OF TUNE.
TUNED BY LEE NOBLE'S RACING CYL HEAD SPECIALIST - FULLY GAS FLOWED COMB. CHAMBERS & INLET/EXHAUST PORTS - STD. INLET VALVES REPROFILED IN STAINLESS STEEL - RACING VALVE SPRINGS
- CAMSHAFTS & ROCKER SHAFTS
FAST ROAD PROFILE CAMS (DAVID NEWMAN) - ROCKER SHAFTS TUFTRIDED
- ROCKER COVERS
CAST ALLOY TYPE (NOT PRESSED STEEL AS ON SOME PRV ENGINES) - EXTENSIVELY RE-SHAPED TO MACHINE OFF REDUNDANT BITS OF CASTING - AFTER MARKET ALLOY OIL FILLER CAP ASS'Y - BOTH COVERS BEAUTIFULLY POWDER COATED IN DURABLE BLACK FINISH (SEE DETAIL PICS). - ORIGINAL 7 mm PLATED HEX FASTENERS UPGRADED/REPLACED BY 8 mm SOCKET CAP STAINLESS STEEL TYPE (See Pics).
- CRANKSHAFT
SPECIALLY SOURCED & RE-GROUND PRIOR TO FITTING
- LIGHT ALLOY BLOCK & CRANKCASE
FITTED RENAULT SUMP (MAKES FOR SHALLOWER INSTALLATION GIVING IMPROVED GROUND CLEARANCE) - PLEASE NOTE - I CAN VOUCH FOR THE INTEGRITY OF THE BLOCK: IT IS NOT CRACKED & TOTALLY NON-POROUS! - BLOCK CASTING No: 7700598018
- UPRATED WATER PUMP
- GENERAL NOTES ON RECONDITIONING
FULLY RECONDITIONED BY PRV SPECIALIST (BILLS FOR OVER £2000 TO PROVE) PRIOR TO INITIAL INSTALLATION & HAS COVERED ONLY 10,600 MILES SINCE (VERIFIED BY DOCUMENTATION & SPEEDO MILEOMETER).
- CARB SET-UP
TRIPLE DELLORTO 'DRLA 40' 1 1/2" TWIN-CHOKE CARBS cw. LINKAGE - NOBLE DOWNDRAUGHT 6-BRANCH INLET MANIFOLD (cw. TWIN VAC. TAKE-OFFS) - GENUINE DELLORTO 60 MM MACHINED ALLOY TRUMPETS (ALSO INCL. IN PRICE: ALTERNATIVE TRIPLE ITG 2" PANCAKE AIR FILTER SET-UP cw. 6-OFF ALLOY STUB TRUMPETS & BACKPLATES ETC.). NB. CARB LINKAGE NEEDS RE-ADJUSTING.
- SOLID STATE IGNITION MODULES
LUMENITION 'Optronic' TWIN COIL SOLID STATE SYSTEM Type: LCK809 (Special Twin 'Optronic' Sensor System Fitted to Contactless Ducellier Type M79 Twin Coil Distributor) - Full Lumenition Instructions Supplied - TWIN BOSCH SUPERCOILS (cw. Ballast Resistors) ON SPECIAL ALU. BACKPLATE FITTED WITH TWIN LUMENITION POWER MODULES - FULLY WIRED - ALSO SUPPLIED: EXTENDED H/T WIRING: COILS TO DISTR. & POWER MODULES TO DISTR. WIRING cw. PLUGS (See Pics). - HIGH QUALITY BOSCH METAL CASE PLUG CAPS & RUBBER DISTR. CONNECTIONS (WELL OVER £750 OF EQUIPMENT HERE ALONE !)
- STARTER MOTOR & ALTERNATOR
PARIS RHONE TYPE
Postby bozzzydmc » Fri Sep 25, 2009 7:24 pm
Blimey Matt
Thats one hell of an engine you have there !
Well done guys in taking the time etc in helping Matt out here
...." One of the many ....."
Postby tourettes tony » Fri Sep 25, 2009 7:41 pm
Benefits
Postby arranj » Fri Sep 25, 2009 8:36 pm
of FREE!
Postby Admin-bloke » Fri Sep 25, 2009 9:01 pm
Matthew, i just noticed that the distributor cap on this engine has like a double king lead on it.I just bought a cap from ebay as a spare and it looks exactly like the one on this one. You can have it as a spare as I bet they are rare.
When you get the engine scan the lumenition instructions and send it to me. see if i can help out there.
Postby mnickels » Fri Sep 25, 2009 10:05 pm
Admin-bloke wrote:Matthew, i just noticed that the distributor cap on this engine has like a double king lead on it.I just bought a cap from ebay as a spare and it looks exactly like the one on this one. You can have it as a spare as I bet they are rare.
Thanks Admin Bloke. Without the contributions of people like yourself, Mike, Arran, Al, TT, Tyson, Martin......the list goes on, I for one would have struggled in my time as a Delorean owner.
