Postby Darren C » Tue May 10, 2011 9:32 pm
UPDATE....
I have had a reply from Stephen Wynne at DMCH today. :D
He is aware of the problems we are discussing and the Blueing of the DMCH joints. He does say that the company who made them for him are no longer around. Curiously he has said that not all of the joints they had made were blued, however he has also seen failure of his non-blued joints. :(
He would also like to make it clear that DMCH has never sold modified VW joints. (we kinda knew it was SpecialT, but it's good to have it confirmed)
He doesn't say however whether they are searching another manufacturer out to make DMCH joints again, the ones he did sell were made 6-7 years ago.
Steve is following this thread too!
We might just solve this for him... ;)
Postby arranj » Tue May 10, 2011 9:45 pm
Darren C wrote:We might just solve this for him... ;)
Let's hope he remembers us when he buys 500 FBJ5003s at £7 each.....! :?
Postby A Van » Tue May 10, 2011 9:53 pm
Thats good he has contacted you Darren, I expect he offered to discuss personally face-face as well?
Postby bandit » Wed May 11, 2011 10:07 am
Mines all done & sorted, big huggs & kisses to Bozzzzzzzzzy, for sending me a replacement set. Took it apart Sunday (had a Me Sen Tec) my mate took the arms to work & pressed the new ones in, built it back up Monday evening.
Just finished off last night by fitting up the ARB & took it a smoke round. Jobs a good 'en.
Also thanks to Darren for bringing it up in the first place.
Jules
Postby Darren C » Wed May 11, 2011 12:34 pm
No problem Ju,
Just to clarify. Your DMCH joints were fitted as recommended, pin across the ways, and re-greased yet they failed after 2500 miles too. :x
Thanks for PM'ing me, and letting me know your Joints were heat BLUED also.
Postby bandit » Wed May 11, 2011 3:52 pm
Yes Darren, The pins were cross-ways (i.e the 'difficult' way to get the split pin through) & greased pretty regularly, I even gave them a shot from new after fitting. I think it comes from being an 'old school' HGV fitter, there were about 75 of the damn things on a eight wheeler, happy days.
Postby bozzzydmc » Wed May 11, 2011 4:25 pm
No probs Jules ... Im sure the new ones will serve you well :)
Postby Darren C » Wed May 11, 2011 10:01 pm
Ok, time for an update.
Arran's sourced Vauxhall joints were delivered today (ironically they cross ref with Jensen too)
Here is the data:
Summary:
We have found the correct body for the DMC joint, but NOT the shaft. The taper on the shaft is wrong. The shaft is too small a diameter and incorrect angle for the Delorean. It also has a shoulder on it :(
I'm still awaiting the Lotus elise joint, I understand that the body needs machining but the shaft is right (tbc) They are made by Delphi too. If the shaft is right maybe if we contact Delphi they could assemble the Lotus shaft into the vauxhall body without hideous re-manufacturing costs to create a DMC joint?
Let's see when it turns up how it looks. I may need to cut both in half to see if this hybrid is possible. :ugeek:
Unless there's another cross ref out there????
NB neither of these joints are Blued, the Delphi looks better quality having a case hardened body, and better fit in the lower arm :D
Postby RobvdVeer » Wed May 11, 2011 10:07 pm
All other measurements taken into account: What is the most critical measurement for the balljoint that wont upset the alignment? I can imagine this to be how 'deep' the tapered end goes into the control arm... so machining the end down would be tricky to get the correct alignment.
Postby Darren C » Wed May 11, 2011 10:20 pm
Hi Rob,
Basically if the body is right it's down to the taper form and length L. This puts the hub at the correct height to the chassis.
ie if L is too long with the right taper the hub will be too high, move the wheel up into the arch and effectively lower the car and visa versa until the shaft is so short it would restrict the movement in the joint when you bolted it up. It has to be equal both sides too, so you must keep to ball joints from one scource fitted to your car as you can see they all differ in size L.
As for machining the shaft....you'd never hold it properly enough once the joint has been assembled, so it's critical that the shaft is right.
