Postby Darren C » Thu May 12, 2011 9:59 pm
And to finally clarify why you cannot use the Vauxhall Viva joint.
Gauge in factory position of hub to lower arm, the shaft is no where near fitting the hub.(look closely)
You can even move the gauge all the way down so it rests on the top of the joint body and the tapers still do not meet. :shock:
Incidentally whilst messing around this evening I found that the shoulders on the Delphi & Firstline tapers are removable sleeves. Not that it matters, the shafts are too small a diameter to be any good.
Regards the Ball Joint Geek... :ugeek:
Postby arranj » Thu May 12, 2011 10:11 pm
Nice one Darren. Out of interest with the shoulder installed would the, and resting the piece of aluminium on the shoulder, would the vertical measurements be correct then?
Basically a bit of insulation tape wrapped around the shaft and job done? Bloody close though?
Al - Vauxhall Cavalier - no circlip groove
- Commer Van, I never did find the ball joint, only that it matched the Ford GT40, and that was made by Armstrong. No real link at all I don't think, but you never know - I suppose all we're looking for is a ball joint that Armstrong made.
Postby Darren C » Thu May 12, 2011 10:22 pm
Hi Arran,
Nice thought....problem is the shoulder sleeve is actually rubbery plastic, its there to hold up the rubber boot only!
Even if it were steel, you couldn't use it to clamp the hub between sleeve and nut as the shaft would just rattle around and fail.
Postby A Van » Thu May 12, 2011 10:22 pm
Postby Darren C » Thu May 12, 2011 10:24 pm
no circlip groove, taper stops short shaft continues parallel, aka VW joint :(
Postby A Van » Thu May 12, 2011 11:26 pm
Ok, maybe lets focus on Vauxhall/Opel
See what others there are.
Postby arranj » Thu May 12, 2011 11:32 pm
There is still Phil's idea of going into a motor factors that is full of Vauxhall ball joints and opening all the boxes! :mrgreen:
Postby Phil349 » Fri May 13, 2011 12:30 am
Excellent work there.
Regarding the lotus joint, I had the circlip groove machined in at the exact same distance from the bottom shoulder as on the DMC joint (measurement G), and im sure size D was fine, definately more than 0.5mm. I cant measure it now, but check out my pics here:
http://postimage.org/gallery/11yu263oo/
Way more than 0.5mm above the circlip. The joints I used are not firstline parts, they are Delphi parts, maybe they are slightly different here. It fits in the lower arm fine once machined down and the cir clip is at the correct height, as shown in the pics.
True its work to get it to fit so a direct fit part would still be better.
Glad to hear you aggree that the taper is correct, I thought it was pretty close from my measurements in december, and the way it felt compared to the special t joint.
The tapered part of the shaft does not protrude the hole in the hub and the nut tightens down well, no washers required.
Shame about the overall length though. I have had the alignment redone and the car drives just fine but what effect would this extra length have to the geometery?
I too have recieved my TC27 ball joint, bit of a dissapointment :lol: but the casing measurements are perfect!!!
Phil349
VIN #: 1128
Postby Darren C » Fri May 13, 2011 7:11 am
Thanks Phil,
We (Al & I) found a thread on a lotus forum highlighting problems with Delphi Lotus joints. Apparently a few have been produced with too small or too large a knurl diameter making them too tight to press into the lotus arm, or too loose a fit. They have even noted differing taper form and shaft length. All from one supplier of the same part. :shock:
I know my lotus ones arn't Delphi, so I'm not surprised in the least mine are different in size.
This is just another good reason to always go OEM with whatever parts you buy for whatever car, unless the alternative is a tried and proven part recommended by someone you know and trust...cheaper is not best :lol:
As for effect on the geometry with a lotus joint in the De: your lower arm will hang 8mm further from your hub. This will pull the wheel in towards the centre of the car at the bottom where it meets the road and increase the distance away from the car at the top. ie effect your CAMBER angle in a negative way.
Postby Daniel Shane » Fri May 13, 2011 7:45 am
Yeah, There was indeed a batch that where made wrong. Either fell out of the wish bone or damaged it trying to press them in.
Mine are from eliseparts.com and are 100% correct for the Elise. So the measurements I gave should be spot on
