Postby A Van » Sat May 14, 2011 7:18 pm
Dan, for 14 dollars is it really worth trying to find a crossmatch that doesnt always work out?
Postby Dan 6511 » Sat May 14, 2011 8:30 pm
No I'm just gonna order a pair from Houston because they will be right. I PM'd Stephen on facebook to ask if he can bring them to eurofest to save shipping and tax :)
Postby A Van » Sat May 14, 2011 8:32 pm
Dan 6457 wrote:No I'm just gonna order a pair from Houston because they will be right. I PM'd Stephen on facebook to ask if he can bring them to eurofest to save shipping and tax :)
Got to be the best way!
Postby arranj » Sat May 14, 2011 8:43 pm
I can bring a set of DMC upper ball joints to Eurofest too if you want Dan
Postby A Van » Sat May 14, 2011 8:52 pm
arranj wrote:I can bring a set of DMC upper ball joints to Eurofest too if you want Dan
Bring em to Badgertec tomorrow!
Postby Darren C » Sat May 14, 2011 9:21 pm
OK
Made a jig and drilled the shaft for the split pins and fitted the joint.
Very good fit, much tighter in the lower arm than the DMCH. :D
As Phil says theres' no problem with a split pin hole weakening the hold as its above the main part of the nut.
Here's a couple of pictures.
Apologies for the filthy dirty car :roll:
Postby tourettes tony » Sat May 14, 2011 9:23 pm
much better :D
Postby Dan 6511 » Sat May 14, 2011 9:25 pm
Looks good Darren. Off topic, but what thread are the nuts for the lower arm bolts?
Postby Darren C » Sat May 14, 2011 9:35 pm
UNF Dan,
Cant remember exacty but somewhere around 5/8"
Postby Darren C » Sat May 14, 2011 10:59 pm
They're 1/2" UNF Dan, just checked the spare stainless nylocks in my shed. :geek:
