Door strut mount repair kit
Re: Door strut mount repair kit
Postby Spudmurphy » Sat Jun 13, 2020 9:50 pm
On which ones - the ones from DeLoreango?
Spudmurphy
VIN #: 11789
Postby DMC1983 » Sat Jun 13, 2020 10:04 pm
The stainless one from Dgo, you have to cut out a small channel on the inside of the roof to fix them. Then fill with expanding foam after a little sealant round the bolts.
Ive just received the cutting disc for my dremel so i will be attempting this soon. I have the roof box bolted down now so after this i can stop worrying about the torsion bar area for a while
Postby DMC1983 » Sat Jun 13, 2020 11:51 pm
As can be seen here...
Screenshot_20200613-234956_Xodo Docs.jpg (1.62 MiB) Viewed 2255 times
Postby Spudmurphy » Mon Jun 15, 2020 11:50 pm
I used a hack saw blade to elongate the channel. I also used a tool shaped like a large hook to remove the foam. Then same as has already been said.
Spudmurphy
VIN #: 11789
Postby Darren C » Tue Jul 21, 2020 10:36 am
Hi Guy's
I make these for Arran & DeloreanGo
Bear with me I'll make another batch soon, now that things are getting back to "normal"
