arranj wrote:Nice one Darren!
So obviously when replacing any existing ball joint you would just carry over your current circlip and it would be fine? The nut thread matches the original, but not if you're replacing the Special T ones. Does the DCUK joint come with a nut? Nylock?
Because we got these made so fast, he was out of stock of the circlips, he said he'd get them in on Monday for us, we can then have them supplied with the joint. You could obviously re-use your old one (if you dont damage it getting it off). But much nicer to use a new shiny one that could come with the joint.
As I've got a drawer full of useless joint's I had plenty of new circlips so fitted one of those today. The joint comes with nylocks, you can request a hole for a split pin, but you'd need to re-use your old nut. We can get these new, but they are blooming expensive for just one nut as again these need to be made to order. To be fair the nylock would be fine. It's just OCD geeks like me that want the "original" look with the split pin.
