Sweet interior on this Russian DeLorean...
Re: Sweet interior on this Russian DeLorean...
Postby Dangermouse » Wed Sep 09, 2015 5:42 pm
Interesting, I have been seeing this one on-line for ages, keen to learn more about it.
So, did the current owner buy it from AutoLehmanns in Moscow?
It didn't appear to be registered there as there are some shots of it in the back of a truck with AutoLehmanns plates on it, so it was recently registerd and for some reason driven to London -
it's not Roman Abramovich's is it?
Ask your friend to read off the VIN number for your :)
There is another one floating around with a very similar plate, also ending in 777.
Postby A Van » Wed Sep 09, 2015 9:27 pm
Walton upon Thames is in the Abramovich territory
Postby Biff » Sat Sep 12, 2015 8:48 am
Not that i know but then again nobody's territory is safe from those Russians.
Sent from my SM-G360F using Tapatalk
Biff
VIN #: 05127
Postby A Van » Mon Mar 21, 2016 7:21 pm
This car is in a 'prestige'garage in Notting Hill, running rich and did have a blocked cat.
They have been buying parts then called up for advice which I was able to give as fairly routine faults
They sent a mechanic to my house to pick up my spare CPR which solved the running rich issue, readjusted mixture
Then the cat was completely blocked due to it running rich for a prolonged period.
Now working on warm start problem which I suspect is injectors leaking.
Postby Admin-bloke » Mon Mar 21, 2016 7:37 pm
Reap the old one back Al, I might be able to rescue it if it doesn't need any parts inside
Postby Admin-bloke » Mon Mar 21, 2016 7:40 pm
Warm start,
Set too Rich
Lambda oxygen sensor chocked/ satiated causing richness
O ring in fuel distributor
Accumulator
Fuel pump check valve
Injectors
Enjoy
Postby mnickels » Mon Mar 21, 2016 8:17 pm
Admin-bloke wrote:Warm start,
Set too Rich
Accumulator
Injectors
Enjoy
My money is on item 2 (based on cat damage following CPR issue), or 3 (based on warm start issue prevention being among its primary roles). Who is doing bookie?
Postby A Van » Mon Mar 21, 2016 8:27 pm
Ah I have already got them to remove cat and run open loop
Postby mnickels » Mon Mar 21, 2016 9:05 pm
A Van wrote:Ah I have already got them to remove cat and run open loop
Always a step ahead!
Have they done a fuel supply pressure test to dizzy, with the ability to shut off before or after gauge? It should tell if pressure is low pre dizzy, or lost post dizzy while warm and engine off. Should then confirm accumulator or injectors...
Postby A Van » Tue Mar 22, 2016 9:28 am
You would think fuel pressure gauges would be something they had wouldn't you.....
