200bhp rebuilt PRV engine/gearbox on eBay
Re: 200bhp rebuilt PRV engine/gearbox on eBay
Postby tourettes tony » Tue Oct 13, 2009 10:31 pm
i found the part number of the carrier, you can see it underneath where the main bearing nuts can be seen
small numbers 16391
big numbers 7700697229
i only looked cos i think the carrier is the same and it will save you stripping it TT
Postby A Van » Thu Oct 15, 2009 9:13 pm
Though I would post a couple of pics of the gearbox now in my car, hats of to Chris N!
Postby jerzybondov » Thu Oct 15, 2009 11:55 pm
Al, that's a manual that came off that engine isn't it? And yours was auto before? So you've swapped?
Postby arranj » Fri Oct 16, 2009 2:12 am
Yes Gez - keep up! :D
Postby cineman » Fri Oct 16, 2009 8:45 pm
Where does the trasmission originally come from ?
Did you had to swap the final drive wheel?
Are the gears spaced the same that in the delo's one?
I put a Renault 25 transmission in giascarcio's car and we had to reverse the final drive. Also the gears are shorter :)
Club Italiano Delorean www.dmc12.it
cineman
VIN #: 1748
Postby dmc4087 » Fri Oct 16, 2009 11:30 pm
I have that gearbox too - the gears are ever so slightly shorter, almost un-noticable - a longer 5th would be fantastic, or just 6th :)
Do you have pics of the conversion Al?
Postby A Van » Mon Oct 19, 2009 9:33 am
I'll have a look for some more pics, the gearbox came from a guy who used it with a carb'ed PRV in a Noble P4, and I had the differential reversed and capped off the speedo.
Postby tourettes tony » Mon Oct 19, 2009 10:59 am
yes al has become one of the manual brothers ;) TT
