Stainless Exhausts : Fitting Days 26 / 27th September
Re: Stainless Exhausts : Fitting Days 26 / 27th September
Postby A Van » Mon Sep 28, 2009 8:58 am
Never mind what Admin did to my ears...you want to see what Julian does to you when you have both hands tied up....
Postby bandit » Mon Sep 28, 2009 10:40 am
A Van wrote:Never mind what Admin did to my ears...you want to see what Julian does to you when you have both hands tied up....
Went in a boy & came out a man, eh! Al.
Yeh, great weekend, big thanks to all, especially malc & Gay for puuting us up.
Jules
Postby bandit » Tue Sep 29, 2009 7:50 am
Tell you what though boys & girls, it's made such a difference to the car. I've had a chance to do a few miles since fitting the system & I'm well impressed. Mine had the stock system complete with 'cat' etc & the car just breathes so much better & revs out lovely.
I was'nt really expecting much difference, I bought it more for a bit more noise than anything, but it's great. I really do recommend them.
Jules
Postby Admin-bloke » Tue Sep 29, 2009 10:30 am
Result there then Jules !
So, will you be sticking it on the rolling road at next eurotec??
Postby arranj » Tue Sep 29, 2009 12:52 pm
Jules - I'm assuming you had some tuning done as well? Would this have made any difference too, or was it set up right beforehand do you think?
Postby arranj » Tue Sep 29, 2009 10:10 pm
Found this on Youtube!:
Postby bandit » Thu Oct 01, 2009 3:23 pm
Admin-bloke wrote:Result there then Jules !
Yeh, might be a plan, would be interesting just to see what it makes.
Postby arranj » Thu Oct 01, 2009 3:25 pm
Can't be worse than Lisa's! :mrgreen:
Postby bandit » Thu Oct 01, 2009 3:41 pm
arranj wrote:Jules - I'm assuming you had some tuning done as well? Would this have made any difference too, or was it set up right beforehand do you think?
Yeh, Nick will tell you better. I know he put a new 'shim' in, but then I think he took it back out, it seemed too rich. After a bit of playing it seemed OK.
Postby Admin-bloke » Thu Oct 01, 2009 3:46 pm
Still not 100% but so close. Recommend fuel injector spray/ prressure test, then fuel distributor volumetric test, then re-check primary fuel pressure and control pressure including CPR Vac pipe again.
Bringing the kit to do all of the above in October if others want tests doing.
Remove your own injectors though, I have bunch'o'banana fingers at times.
