Servicing Items and Part Numbers
Postby Chris Hawes » Wed Jun 18, 2014 9:07 pm
How about we create a new section of the forum that has a nice simple all in one check list of items needed for servicing the car and crucially the part numbers?
The parts cross reference section is building up nicely but another as a one stop location for all the service related parts would be nice and convenient when it comes to time for a service?
I'll start with what I know in regard to the items that need checking/replacing but sure there must me more parts/items I've not covered:-
Servicing
Oil 10/40 semi synthetic – 6000 miles/annually Volume needed from empty ?
Oil Filter
brake fluid – change every two years?
Grease nipples on control arms for ball joints upper and lower
Dist Cap (every 12,000 miles?)
Rotor Arm (every 12,000 miles?)
Air filter
coolant – 50% mix? Which type/does it matter
clutch fluid (dot4 only) volume from empty required ?
spark plugs
fuel filter
brake pads – greenstuff
Belts
aircon belt
altnerator belt
aircon
R134a gas (amount required 950g?) Oil amount?
Orifice tube
Accumulator
check for play in balljoints
The above lacks the current part numbers. I know some of those previously published are no longer correct/current so any help with publishing those that are known to be current/correct would be great.
Regards,
Chris Hawes
Chris Hawes
VIN #: Ex owner of 5255
Re: Servicing Items and Part Numbers
Postby MikeWard » Thu Jun 19, 2014 11:34 am
Chris Hawes wrote:Servicing
Oil 10/40 semi synthetic – Every 6 months regardless of mileage - 6 litres?
Oil Filter – Mahle OC460
Air filter – Mahle LX689
Grease upper and lower ball joints – Every 12 months
Distributer Cap – Intermotor 44030
Rotor Arm - Intermotor 47080s
Spark Plugs - Bosch HR6DC+
HT Leads - PFV902576 (Volvo 260/760 series B28 Ignition Lead set)
Fuel Filter – Bosch 0 450 905 401 every 10,000 miles or 2 years whichever comes first
Coolant 50/50 mix - Bluecol Antifreeze & Summer Coolant 5L 2 Year Protection – change every 2 years
Brake Fluid DOT 4 - Change every 2-3 years
Clutch Fluid DOT 4 – Change every 2-3 years
Brake Pads – EBC Greenstuff pads, rears DP2101, fronts DP2291
Brake Pads – EBC Redstuff pads, rears DP3101C, fronts DP3291C
Handbrake Pads – EBC Blackstuff DP709
Belts
A/C Drive Belt – Gates Auto Master 6234mc
Alternator Drive Belt - Gates Auto Master 6230mc
Fuel Accumulator - Bosch 0 438 170 029
Gearbox fluid - 75w90 Castrol Syntrans Transaxle (manual transmission/final drive) - Change every 3-5 years
Amended with comments/part numbers.
Postby bandit » Thu Jun 19, 2014 2:43 pm
What's with the changing oil every 6 months regardless of mileage? What a complete waste of money!
Postby RobvdVeer » Thu Jun 19, 2014 2:45 pm
i'm with bandit on this one. But a big thank you for adding those part numbers!
Postby MikeWard » Fri Jun 20, 2014 8:52 am
bandit wrote:What's with the changing oil every 6 months regardless of mileage? What a complete waste of money!
Ju, that's just the way I do mine, I know most owners would/should do theirs on a 12 month cycle, which is absolutely fine given the limited number of miles most people do.
My car gets a fair bit of use though, so I would rather change it out every 6 months (just my own personal preference), and since it's less than the cost of what I would spend on a night out on the tiles, at least it's not something which is literally getting peed away within a matter of hours.
Postby A Van » Fri Jun 20, 2014 4:31 pm
Thanks for updating Mike and good idea Chris
Postby Admin-bloke » Fri Jun 20, 2014 5:37 pm
To be fair I did the same on mine re oil changes at first to give it a good flushing out. Same with my auto oil...
Postby bandit » Fri Jun 20, 2014 11:00 pm
I get it IF your covering the miles, but changing it every 6 months regardless of miles just seems a bit daft. It's no different sat in the sump, than it is in 5 litre can on a shelf.
Postby Chris Hawes » Tue Jul 22, 2014 9:50 pm
Thanks for the comprehensive list Mike.
I now have all the bits except for:-
None of the motor factors I went to recognised the above part number. Any more information available so I can help source the right set?
Which version of the B28 is the DeLorean as I think there were multiple variants of the B28???
Regards,
Chris Hawes
Chris Hawes
Postby Dan 6511 » Tue Jul 22, 2014 10:11 pm
Early 80's Volvo 760. B28E engine. I've had a B and a C reg and both had the right engine, it's the newers ones that have the wrong engine. I've had 2 of these volvos with the same engine and the HT leads are identical to the D :)
