Frame epoxy
Frame epoxy
Postby Dan 6511 » Mon Jun 23, 2014 10:41 am
What is the best stuff these days for painting the frame?
I have some epoxy lifted off where the brake master has leaked which needs sorting out before I put the tank back in.
Re: Frame epoxy
Postby Dan 6511 » Mon Jun 23, 2014 11:20 am
Re: Frame epoxy
Postby jerzybondov » Mon Jun 23, 2014 11:40 am
I put Chris N onto this and now he won't use anything else:
http://www.frost.co.uk/por15-gray-rust- ... 473ml.html
Re: Frame epoxy
Postby Dan 6511 » Mon Jun 23, 2014 11:55 am
It's not really protected your chassis very well though Gez ;)
Re: Frame epoxy
Postby andyd » Mon Jun 23, 2014 12:32 pm
Dan 6511 wrote:It's not really protected your chassis very well though Gez ;)
:lol: Ha! Dan's being cunty!
I would recommend POR-15. Use with marine clean first, and thentheir metal ready, follow the intructions to the letter, and I was quite pleased with the result.
Horifically expensive however, and tin, once open, does not keep for long. Best get all the bits ready to paint, and do it all at once. A few coats, over the space of a few days.
Nice result, especially if you take your time and are careful, and its a reasonable match for the original epoxy, not that I am too bothered about that. Just the cost that bugs me. And throwing out half a tin of expensive set paint, before paying thru the nose for more!
a
Re: Frame epoxy
Postby Admin-bloke » Mon Jun 23, 2014 12:40 pm
Dan 6511 wrote:What is the best stuff these days for painting the frame?
Go on Dan, do another frame off. You know you want to ;)
Re: Frame epoxy
Postby jerzybondov » Mon Jun 23, 2014 12:45 pm
To be fair, the bits I redid with POR15 are fine. It's the insides of it I couldn't reach that are the problem!
Re: Frame epoxy
Postby stevie67cars » Mon Jun 23, 2014 3:29 pm
Dan 6511 wrote:Anyone ever used this?
http://www.ebay.co.uk/itm/330769768495?redirect=mobile
That's what I used for my chassis Dan, great stuff, lovely finish too, looks like it was sprayed- I used a small roller for most of it and a paintbrush where the roller couldn't get. Then I sprayed some of this into box sections and other areas of the chassis to protect it, brilliant stuff, can't recommend it highly enough, I have used it a good few times over the years.
http://www.bilthamber.com/cavity-waxes
Stephen
stevie67cars
VIN #: 10213
Re: Frame epoxy
Postby Daniel Shane » Mon Jun 23, 2014 6:07 pm
Por 15 is excellent stuff.
Redoing the Elise suspension in it as we speak.
Best thing to do is get some disposable plastic contains and decant it into that. So far mine has kept for 2 years without any problems.
Re: Frame epoxy
Postby Darren C » Mon Jun 23, 2014 10:43 pm
Ditto, on whats been said about the POR 15. The quality of the protection is all in the prep, not the epoxy.
Good colour match is the only issue with spot repairs.
