Louvre Latch
Louvre Latch
Postby Ali66 » Fri Sep 12, 2014 8:57 am
Hi chaps,
I wonder if any of you have experienced this - The latch that I assume keeps the louvre down doesn't seem to grip on to anything on my D. You can simply lift the louvre up from anywhere at any time.
I'm worried that if I'm going along and going over a bump, it will crash about or may even break the louvre. Has anyone had this before? The latch doesn't seem broken but also doesn't seem to clip onto the engine cover loop thing provided.
Do you reckon it will be safe to drive like that for a while?
Cheers!
Alex
"That Punk Calvin Klein"
VIN 3759
Sept 81
Black Interior
Auto
Ali66
VIN #: 3759
Re: Louvre Latch
Postby RobvdVeer » Fri Sep 12, 2014 9:45 am
Total nonsense removed. i should know better :text-imnewhere:
Re: Louvre Latch
Postby Ali66 » Fri Sep 12, 2014 10:02 am
Sweet, thanks Rob. Although, the Engine grill doesn't latch down either :lol:
Alex
VIN 3759
Sept 81
Black Interior
Auto
Ali66
VIN #: 3759
Re: Louvre Latch
Postby A Van » Fri Sep 12, 2014 10:05 am
The latch on the louvre probably isn't lining up with the catch
Re: Louvre Latch
Postby A Van » Fri Sep 12, 2014 10:09 am
Put a little paint on the engine cover latch then lower the louvre, you can then see how far off it is
Usually taking the latch off the grill bending it back a bit then refitting means it lines up
If it doesn't click the louvres will bounce around
Re: Louvre Latch
You shouldn't be able to just lift the louvre up
Re: Louvre Latch
Postby RobvdVeer » Fri Sep 12, 2014 10:11 am
A Van wrote:You shouldn't be able to just lift the louvre up
Yes, i must admit i'm wrong. There actually is a little latch... sorry.
Re: Louvre Latch
Postby Ali66 » Fri Sep 12, 2014 10:13 am
A Van wrote:The latch on the louvre probably isn't lining up with the catch
Is that common/easy fix? Are you saying that there is a latch on the louvre not a magnet?
Having just had a look, there does appear to be some kind of spring loaded latch mechanism on the underside of the louvre that you can activate a bit like a clip. It's not holding on to anything though...
Alex
VIN 3759
Sept 81
Black Interior
Auto
Ali66
VIN #: 3759
Re: Louvre Latch
Postby Ali66 » Fri Sep 12, 2014 10:17 am
Sorry, by the time I'd posted that, you'd cleared it up lol!! Thanks guys, I'll try the paint method later
Alex
VIN 3759
Sept 81
Black Interior
Auto
Ali66
VIN #: 3759
Re: Louvre Latch
Postby Ali66 » Sat Sep 13, 2014 6:18 pm
Me again!
So yeah, it looks like the louvre latch is misaligned with the catch on the engine grill. However, the engine grill doesn't stay down either, it can be just lifted willy-nilly.
Has anyone had this before? There doesn't appear to be anything on the underside of the grill - it's just smooth with a hole. I don't see how it locked down unless there is something missing from it?
Alex
VIN 3759
Sept 81
Black Interior
Auto
Ali66
VIN #: 3759
