Front / rear facias paint and mis shaped -ness..
Postby clocktown64dd » Sat Nov 28, 2015 11:28 am
I'm going to have a go at painting the front and rear facias. The black isn't a problem but what colour / paint code / RAL number paint do people go for to get the best result / colour? Also my front bumper has a saggy middle over the front badge, what method works best for getting this back to normal?
Thanks!
clocktown64dd
Re: Front / rear facias paint and mis shaped -ness..
Postby MikeWard » Sat Nov 28, 2015 12:37 pm
Drop me a PM with your email address and I'll send you the official paint formula from Dmc. Whether you will be able to find a paint shop who can make it up though is another question.
Most people use an off the shelf Alfa Romeo colour:
Alfa Romeo, Grigio Antares Stromboli Met. Code 651A
It's in the ballpark, but it is not an exact match (lighter than the original).
Here is a comparison between an original bumper and one painted in the Alfa colour:
https://www.dropbox.com/s/yrpdo1lkkhmdx ... 9.jpg?dl=0
https://www.dropbox.com/s/jiel6uihj67jn ... 0.jpg?dl=0
https://www.dropbox.com/s/k95enail51t5m ... 4.jpg?dl=0
Postby bandit » Sat Nov 28, 2015 3:01 pm
I used the 651A, in fact I posted it up after having mine scanned with a digital paint scanner. I'm pretty sure mine were as factory, so seems its as close as you'll ever get.
Postby clocktown64dd » Sat Nov 28, 2015 3:15 pm
Wow fantastic. Do you need to do an under primer? And lacquer? Stupid question I know!
clocktown64dd
Postby clocktown64dd » Sat Nov 28, 2015 3:16 pm
Also any ideas about the mis shaped front facia?
clocktown64dd
Postby MikeWard » Sun Nov 29, 2015 5:20 pm
clocktown64dd wrote:Also any ideas about the mis shaped front facia?
Speak to Gary Dunster (username minispeedster) he is a dab hand at straightening out fascias.
Postby bandit » Sun Nov 29, 2015 8:13 pm
Yes you'll need primer & clear coat
Postby clocktown64dd » Mon Nov 30, 2015 10:45 pm
Il give him. Shout :)
And would it be a plastic primer? Of would any old primer be okay?
clocktown64dd
Postby bandit » Tue Dec 01, 2015 3:58 pm
I think they just use a 'normal' primer, but I'm no expert in this field (or any other for that matter :lol: ) if you run it past a car painter, I'm sure they can tell you what's what
Postby minispeedstar » Tue Dec 01, 2015 8:30 pm
Use a good quality acrylic primer, just don't load it on too thick. That'll be fine. :)
minispeedstar
