Angle Drive Replacement?
Postby Dan 6511 » Thu Nov 22, 2018 4:56 pm
Just found these GPS to mechanical speedo convertors. This could be a possible modern replacement to the angle drive. Mount it near the steering column with a short cable up the speedo. Has anyone come across these before?
https://www.speedhut.com/ecommerce/product/2585/SPEEDBOX%E2%84%A2-GPS-VSS-to-Mechanical-Drive-Speed-Converter
Re: Angle Drive Replacement?
Postby MikeWard » Thu Nov 22, 2018 6:29 pm
Hi Dan, there is some discussion on this over on dmctalk: http://dmctalk.org/showthread.php?16622-Bye-Bye-angle-drive!
Postby Dan 6511 » Fri Nov 23, 2018 11:12 am
Thanks Mike. Good to know it actually works then. I might get one of them when my car is eventually running :thumbsup:
Postby CFI » Sat Mar 02, 2019 2:36 pm
I installed one recently. Very easy install and it works great,
Here’s my write up: http://dmctalk.org/showthread.php?17195 ... t=SpeedBox
CFI
