VIN 5219
Re: VIN 5219
Postby DMC1983 » Wed Aug 28, 2019 6:07 pm
Thanks guys. Ive sent around 10 pictures to the owners club so hopefully 1 or 2 will be in next years calendar.
Re: VIN 5219
Postby DMC1983 » Sat Aug 31, 2019 2:41 pm
Mike ward approved front number plate is now on. And what a difference. So prefer this over the previous one i had on
This also means i have a front number plate bracket if anyone wants it.
Re: VIN 5219
Postby DMC1983 » Thu Sep 05, 2019 2:40 pm
A few more ideas for my number plate abbreviation
Frequently No Problem ( :lol: )
Forever Needing Petrol
Finding Numerous Problems
Faults Not Present ( :lol: )
Fiddly Niggling Places
Previous suggestions:
Fucking No Power
Fucking Nightmare Project
Re: VIN 5219
Postby DMC1983 » Sun Sep 08, 2019 7:51 pm
Damnit. Drivers door handle just broke on me. Im not surprised really. Looks like replacement handles are at the top of the to buy/do list now
Any tips for when i change over to metal?
Re: VIN 5219
Postby mec » Sun Sep 08, 2019 11:19 pm
mind the sharp edges inside the door, they will cut you to bits
Re: VIN 5219
Postby A Van » Mon Sep 09, 2019 7:00 am
Passenger side one
The socket has to go at a bit of an angle and can slip off easy and get lost in the door
Put a bit of tape round it
Re: VIN 5219
Postby DMC1983 » Mon Sep 09, 2019 1:51 pm
Good tips, thanks
Re: VIN 5219
Postby DMC1983 » Wed Sep 25, 2019 8:01 pm
Ive noticed today that the engine cradle has oil on it now on the front and back lips. The trans just above the cradle is also wet in places. Can the oil travel that far (from the pulley crankshaft end where i know is a leak) or is it as i fear the seal behind the clutch like in the Wheeler Dealers episode? Basically do i have to replace both the seals now? I check the oil regularly too and it doesnt appear to be going down. Could there be a trans leak instead? I dont think its coming from the lip/O ring seals but i havent ruled those out either. It looks dry around that immediate area.
My idle was playing up a little today too. Whilst i was at the lights i noticed the car would rev by itself to the 1500 rpm mark then back down to just under 1000 rpm like it should. It would do this roughly every 5 seconds or so. Any ideas?
Re: VIN 5219
Postby gary290 » Wed Sep 25, 2019 10:05 pm
put up a pic of the oil
gary290
VIN #: 17005
Re: VIN 5219
Postby Dan 6511 » Thu Sep 26, 2019 7:57 am
Gearbox oil stinks. If it just smells like normal engine oil then its not your gearbox.
It sound exactly like crank seal behind the flywheel to me. Mines weaping as well at the moment.
