What's the latest on replacement windscreens?
Postby jerzybondov » Fri Aug 28, 2020 11:56 am
I got hit by a massive stone on the motorway the other day and the crack is growing. I think it's done.
What's the latest on replacement windscreens? I had a new one through autoglass in 2009, but at the time I remember there was only one guy there who knew how to do a DeLorean windscreen. Anyone had a replacement more recently than that and know what the shizzle is?
Re: What's the latest on replacement windscreens?
Postby A Van » Fri Aug 28, 2020 12:13 pm
Chris N will quote the insurance company
Postby jamesrguk » Fri Sep 04, 2020 8:05 pm
I had AutoGlass do mine 2 years ago, 2 week wait, no issues to speak off, it's not particularly challenging to fit.
My only disappointment was the quality of thr screen which has a slight ripple in the driver's eyeline, once you've spotted it you can't un-upot it.
Sent from my SM-G973F using Tapatalk
Postby DMC1983 » Sat Sep 05, 2020 4:13 am
I remember screencapping this from facebook quite a while ago if this helps
Screenshot_20191102-102858_Samsung Internet.jpg (1.46 MiB) Viewed 2849 times
Postby eric » Sat Sep 05, 2020 5:43 am
Useful tip from http://support.delorean.com/kb/a74/windshields.aspx,
CAUTION: With the windshield removed and the doors open, the roof may actually sag slightly. If the new windshield is glued in place and allowed to cure with the doors open, you'll find that the doors do not close well any more. To prevent this, it is extremely important that you close the doors as soon as the glass is set in place, and keep them closed for at least 12 hours.
I did read you should prop the roof when doing it....re-enforced a bit here http://dmctalk.org/showthread.php?600-W ... eplacement
Bummer about your ripple James, I had the same in a previous car and you are right once you have seen it , it always catches your eye....
Postby jamesrguk » Sat Sep 05, 2020 7:52 am
eric wrote:...Bummer about your ripple James, I had the same in a previous car and you are right once you have seen it , it always catches your eye....
Yeah it's not bad enough to warrant changing it, I've no doubt I'll need another one at some point in the next few years anyway.
