Tdc through valley plug
Postby Andy_ » Mon Jun 10, 2024 1:23 pm
I’ve stripped the engine down and removed the cylinder plug in the valley to setup the distributor.
Im looking through the plug hole and can see the #6 counterweight, but theres 3 holes in it, i was only expecting to see 1. Which hole should the bolt drop into, to lock at tdc #1 ???
The 8mm bolt im using will drop into all 3 holes.
Im following this guide;
https://dmctalk.org/showthread.php?1393 ... -Liter-PRV
And this youtube video;
https://youtu.be/uuxPWCdnW_0?si=3v3h3HgemzfcO3-g
Any help gratefully appreciated!
Andy_
Re: Tdc through valley plug
Postby Andy_ » Mon Jun 10, 2024 1:26 pm
There seems to be 3 holes and 2 slots in the end of the counterweight
Andy_
Postby Admin-bloke » Tue Jun 11, 2024 11:11 am
Remove the spark plug from no1 and use a long stick/ screwdriver to determine it is at top dead centre
Also remove the rocker cover and make sure that the valves are shut (gaps between the rocker and valve top) verifying that it is on the compression stroke
Then use the drill to lock the crank on that hole, then check the timing gauge near the crank is set to 0 to the TDC mark
