Used but good Delorean engine PRV6 parts at good prices. Please PM or e-mail for prices
If you want something thats not listed - call me as I might have it!!!
Fuel injection
K- jetronic Metering heads for Volvo 260 - these are stored submersed in light oil
Air flow sensors - Delorean & Volvo
Control pressure regulators (warm up regs) - Delorean & Volvo
Freqency valves
OEM Fuel lines
Bosch injectors- used but tested
cold start injectors
Banjo bolts - all sizes
Engine & components
Complete engine from Volvo 760 - This engine come from a running car, low miles and was k-jetronic. although it will only come 'engine only' with no ancillaries, no injection system, inlet manifold or waterpump. This engine has a Volvo sandwich plate and sump and will need to be swapped with your old engine for it to mount in a Delorean Chassis
Loads of Delorean PRV6 engine internals :-
Pistons + Conrod B28E
Pistons + conrod B28F
Piston liners
Crank shafts - stock
Cam shafts - stock
Used Cylinder heads
Refurbed cylinder heads - Head cleaned, Head gasket face and exhaust port faces skimmed, Exhaust studs retapped to 8mm, Valves cleaned and re-lapped, new stem seals.
Rocker covers
Timing covers
Timing chains
Cam sprockets
Crank sprockets
Inlet manifolds
Exhaust manifolds
New Waterpumps - complete with backplate and pulley, will need your old one as exchange
various water hoses for delorean cooling system
Various engine PRV6 gaskets + 'O' rings
Various size Jubilee clips
