Used but good Delorean engine PRV6 parts
Jason's big garage clearout!
Postby delorean12uk » Wed Jan 15, 2014 10:08 pm
Used but good Delorean engine PRV6 parts at good prices. Please PM or e-mail for prices
If you want something thats not listed - call me as I might have it!!!
Fuel injection
K- jetronic Metering heads for Volvo 260 - these are stored submersed in light oil
Air flow sensors - Delorean & Volvo
Control pressure regulators (warm up regs) - Delorean & Volvo
Freqency valves
OEM Fuel lines
Bosch injectors- used but tested
cold start injectors
Banjo bolts - all sizes
Engine & components
Complete engine from Volvo 760 - This engine come from a running car, low miles and was k-jetronic. although it will only come 'engine only' with no ancillaries, no injection system, inlet manifold or waterpump. This engine has a Volvo sandwich plate and sump and will need to be swapped with your old engine for it to mount in a Delorean Chassis
Loads of Delorean PRV6 engine internals :-
Pistons + Conrod B28E
Pistons + conrod B28F
Piston liners
Crank shafts - stock
Cam shafts - stock
Used Cylinder heads
Refurbed cylinder heads - Head cleaned, Head gasket face and exhaust port faces skimmed, Exhaust studs retapped to 8mm, Valves cleaned and re-lapped, new stem seals.
Rocker covers
Timing covers
Timing chains
Cam sprockets
Crank sprockets
Inlet manifolds
Exhaust manifolds
New Waterpumps - complete with backplate and pulley, will need your old one as exchange
various water hoses for delorean cooling system
Various engine PRV6 gaskets + 'O' rings
Various size Jubilee clips
Re: Used but good Delorean engine PRV6 parts
Postby ALEXAKOS » Sat Jan 18, 2014 7:42 pm
PM SENT!:)
Postby OB1 » Fri Apr 06, 2018 1:10 pm
Many thanks....
OB1
VIN #: 3283
Postby stevie67cars » Fri Oct 05, 2018 12:33 pm
How much for a refurbed cylinder head? The RH one as you stand behind the car. Thanks
Stephen
stevie67cars
VIN #: 10213
Return to Jason's Parts
