Hi all
A few updates for you over the last week, i picked up a 2nd hand window regulator to replace the bodged one that was in the car, this was a massive £35 so very good value in my opinion...
- 20191004_103452 (Medium).jpg (355.51 KiB) Viewed 5908 times
Whilst i was in the door I sorted out door lock too, it didn't work properly, this turned out to be a snapped return spring which was laying on top of the lock, i nicked a coil out of the spring and bent it into a hook shape and reattached it, a nice free fix ..
- 20191004_110730 (Medium).jpg (263.21 KiB) Viewed 5908 times
Also when i took the door card off it was pretty much in half...
- 20191006_221831 (Medium).jpg (222.34 KiB) Viewed 5908 times
So this was easily repaired with some oversize washers
- 20191006_222920 (Medium).jpg (214.53 KiB) Viewed 5908 times
I then cleaned all the black sticky stuff off the inside..
- 20191006_235931 (Medium).jpg (217.98 KiB) Viewed 5908 times
and put everything back together, the window and lock are now working great, I then turned my attention to the rusty wing, I was just going to replace it, however with this being a budget project I thought Id have a go at repairing it 1st , here's the wing before...
- 20191008_145539 (Medium).jpg (221.71 KiB) Viewed 5908 times
I cut it back to good metal and started making a panel...
- 20191008_201637 (Medium).jpg (93.43 KiB) Viewed 5908 times
this then turned into this ...
- 20191008_213351 (Medium).jpg (241.66 KiB) Viewed 5908 times
- 20191008_213357 (Medium).jpg (237.43 KiB) Viewed 5908 times
I welded the 1st "curved section" from the back so there would be minimal dressing needed on the front groove
- 20191008_220156 (Medium).jpg (166.3 KiB) Viewed 5908 times
the other section I welded from the front as this bit is flatter and has to curve in a different way..
- 20191008_220332 (Medium).jpg (186.12 KiB) Viewed 5908 times
- 20191009_093411 (Medium).jpg (237.54 KiB) Viewed 5908 times
there was also this hole hiding under the filler..
- 20191009_095611 (Medium).jpg (194.37 KiB) Viewed 5908 times
I had to weld a plate in from behind as the metal was so thin, there was also a small rust hole a bit further round the arch, this was small enough to weld up ..
- 20191009_095815 (Medium).jpg (163.69 KiB) Viewed 5908 times
finally this is the wing test fitted back on...
- 20191009_104734 (Medium).jpg (134.11 KiB) Viewed 5908 times
- 20191009_104746 (Medium).jpg (206.71 KiB) Viewed 5908 times
Its by no means perfect but a lot better than the previous repair, It bolts into the original holes now as least !
It will require some filler, hopefully this will make the repair look nice and tidy, we will see i guess, this will be the next step. on we go, Hopefully another update coming soon
