Double Glazing - anyone in the know?
Postby Manxmann » Mon Nov 28, 2011 8:22 pm
Hey chaps,
Anyone know anything about double glazing?
I'm struggling to replace the beading on a small window, approx 11"x8". I've put in the two 'short' sides but cannot bend the 'Long' sides enough to get both ends in.
Anyone have any tips/tricks, I've managed to get all the other windows in, its just the darn little begger thats causing all the trouble.
The Manx 'D' - VIN 17152
Manxmann
VIN #: 17152
Re: Double Glazing - anyone in the know?
Postby tourettes tony » Mon Nov 28, 2011 8:57 pm
short ones in first, and tap them all in with either the rubber end of a hammer or plastic hammer of some sort , you must put both ends in first then push and tap TT
Postby hana 5284 » Mon Nov 28, 2011 9:46 pm
Yes like tone said put the sides in first normaly but just depends on which ones are a straght cut on the ends could be top and bottom you must get the lip of the bead under the lip in the frame then normaly push it down tight with one hand and smack the f##ker like hell with the other side of you hand ( don't worry the glass won't brake) job done.
If the window brakes and you cut your hand off it's your fault ;)
Cheers tys
Postby Darren C » Mon Nov 28, 2011 10:36 pm
It sounds daft, but run a HOT bath, drop em in for 10 mins, then rush to window and fit. They'll bend easier.
Once finished, stand back, admire then take a free bath. :lol:
Postby Manxmann » Mon Nov 28, 2011 11:14 pm
Darren C wrote:It sounds daft, but run a HOT bath, drop em in for 10 mins, then rush to window and fit. They'll bend easier.
Cheers gents, knew I could rely on you guys for some advice.
Yes I'd put the two short ends in but just couldn't bend the long, if you can call them that, sides enough to get both ends in. I was worried I'd break the little f*ckers.
I will give them the hot water treatment a try in the morning.
Manxmann
VIN #: 17152
Postby Darren C » Tue Nov 29, 2011 8:09 am
Hi Manx,
It will be easier if you take out 1 of the short lengths. ie,
1. put in bottom (short length if portrait window)
2. put in 1 side
3. put in top
4 put in last side.
This way you will have only 1 length thats awkward to bend and get in. If its only 11" long I'd put it in a bucket of boiling water for a couple of minutes.
Good luck. :D
Postby bozzzydmc » Tue Nov 29, 2011 9:56 am
After reading all this there is only one word that keeps coming into my head ...
SNAP !!!
Postby Manxmann » Tue Nov 29, 2011 6:01 pm
LOL well snap it didn't!
Quick douse in boiling water and hey presto!
Cheers guys
Manxmann
VIN #: 17152
Postby DMCDELLBOY » Tue Nov 29, 2011 9:57 pm
I have been in double glazing for 25 years and my tip is to snip the inside of the inside of the beed and spray with glass cleaner and use a plastic mallat but i some time still have problems just put the beeds back the way they come out.
DMCDELLBOY
VIN #: 11075
