Lathe ??
Lathe ??
Postby bozzzydmc » Fri Apr 05, 2013 2:57 pm
Hi all
I'm trying to get some 30mm diameter aluminium rods lathed down in a conical shape to 10mm at the other end
It is 6 pieces all 60mm long
Anyone got any ideas please
Re: Lathe ??
Postby A Van » Fri Apr 05, 2013 7:13 pm
Get them sent to me Bozzy, my mate can do it
I expect Barren could as well
Re: Lathe ??
Postby bozzzydmc » Fri Apr 05, 2013 7:28 pm
That would be great Al !
I will give you a call to see how best to send this
Maybe I should run a competition to guess what they are for ;)
Re: Lathe ??
Postby A Van » Fri Apr 05, 2013 7:36 pm
Ok I can send back no issues via courier, just need to get them to me.
Btw the labour prices are increasing daily, I predict £30ph by Xmas!
Re: Lathe ??
Postby bozzzydmc » Fri Apr 05, 2013 7:51 pm
;) that I like x
Re: Lathe ??
Postby MikeWard » Fri Apr 05, 2013 8:17 pm
bozzzydmc wrote:Maybe I should run a competition to guess what they are for ;)
Green tubes? ;)
Re: Lathe ??
Postby bandit » Fri Apr 05, 2013 8:19 pm
Butt plugs?
Re: Lathe ??
Postby bozzzydmc » Fri Apr 05, 2013 8:37 pm
Green tubes? ;)
Tiny little 60mm long tubes maybe Mike :)
Sell me your dash boxes :) xx
Re: Lathe ??
Postby Darren C » Fri Apr 05, 2013 10:37 pm
I'll wiz em down on my lathe in exchange for you booking for Carfest ;)
Re: Lathe ??
Postby Darren C » Sat Apr 06, 2013 6:18 pm
If you put your mind to it, you can make pretty much anything, dad, dad, daddy o!
Today I decided to sort out some door handles I got for my Ferrari restoration. They are as rare as a tax refund for JZD!
After searching high and low I managed to track down some from a guy who’d changed his 10 years ago and still had the old broken ones. After a bit of negotiation I managed to get them for several thousand pounds less than a working second-hand set.
However the cheap Mazak operating paddle was completely missing on one (seized and snapped off long ago) and the other had a single snapped leg and was bent and worn out. :evil:
So I roughed some new ones out of a solid Stainless Steel Bar, with nothing but a hacksaw and file.
And made two to replace the missing one and the one with one arm.
Result :D
So your cones will be a doddle Bozzy!
