Tools: Your Friends
Tools: Your Friends
Postby DeLorean Cars » Sat Jan 23, 2010 3:07 pm
The True Definition Of Tools
PILLAR DRILL: A tall upright machine useful for suddenly snatching flat
metal bar stock out of your hands so that it smacks you in the chest
and flings your beer across the room, splattering it against that
freshly painted part you were drying.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere
under the workbench with the speed of light. Also removes fingerprint
whorls and hard-earned guitar calluses in about the time it takes you
to say "Ouch...."
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their
holes until you die of old age.
PLIERS: Used to round off bolt heads.
HACKSAW: One of a family of cutting tools built on the Ouija board
principle. It transforms human energy into a crooked, unpredictable
motion, and the more you attempt to influence its course, the more
dismal your future becomes.
MOLE-GRIPS: Used to round off bolt heads. If nothing else is
available, they can also be used to transfer intense welding heat to
the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various
flammable objects in your shop on fire. Also handy for igniting the
grease inside the wheel hub you want the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older cars and
motorcycles, they are now used mainly for impersonating that 9/16 or
12mm socket you've been searching for the last 15 minutes.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground
after you have installed your new brake shoes, trapping the jack
handle firmly under the bumper.
EIGHT-FOOT LONG PINE 2X4: Used for levering an automobile
upward off a hydraulic jack handle.
TWEEZERS: A tool for removing wood splinters.
SCREW EXTRACTOR: A tool ten times harder than any
known drill bit that snaps off in bolt holes you couldn't use anyway.
TWO-TON ENGINE HOIST: A tool for testing the tensile strength on
everything you forgot to disconnect.
CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large prybar that inexplicably
has an accurately machined screwdriver tip on the end opposite the
handle.
TIN SNIPS: See hacksaw.
LEAD LAMP: The home mechanic's own tanning booth. Sometimes called
a drop light, it is a good source of vitamin D, "the sunshine
vitamin," which is not otherwise found under cars at night. Health
benefits aside, it's main purpose is to consume 40-watt light bulbs at
about the same rate that 105-mm howitzer shells might be used during,
say, the first few hours of the Battle of the Bulge. More often dark
than light, its name is somewhat misleading, especially for its propensity to point
everywhere except in the direction you actually want to look at something (usually settling
on "strait in your eyes" instead).
ANGLE GRINDER.: Used mainly to burn neat holes in whichever
part of your clothing is nearest to the object being attacked, and to remove
fingernails.
PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style
paper-and-tin oil cans and splash oil on your shirt; but can also be
used, as the name implies, to strip out Phillips screw heads.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning
power plant 200 miles away and transforms it into compressed air that
travels by hose to a pneumatic impact wrench that grips rusty
bolts last over-tightened 50 years ago by someone at Jaguar, and neatly
snaps off their heads.
PRY BAR: A tool used to crumple the metal surrounding that clip or
bracket you needed to remove in order to replace a 50p part.
HOSE CUTTER: A tool used to cut hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is
used as a kind of divining rod to locate the most expensive parts not
far from the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of
cardboard cartons delivered to your front door; works particularly
well on contents such as seats, vinyl records, liquids in plastic
bottles,collector magazines, refund cheques, and rubber or plastic
parts -- also skin.
DAMMIT TOOL: Any handy tool that you grab and throw across the garage
while yelling "DAMMIT" at the top of your lungs. It is also the next
tool that you will need.
EXPLETIVE: A balm, usually applied verbally in hindsight, which
somehow eases those pains and indignities following our every
deficiency in foresight.
Re: Tools: Your Friends
Postby bozzzydmc » Sat Jan 23, 2010 3:17 pm
PMSL !!
Doh... i did this only yesterday !!!!
Best list 'like this' Ive seen :)
Postby RobvdVeer » Sat Jan 23, 2010 3:45 pm
This list has my vote :D:D:D:D
One is missing though:
GLUE GUN:
Device capable of delivering sticky and unremovable goo to places that are usually in plain sight and didn't need to be sticky or disfigured with unremovable glue remains.
