Badger-tec!
Badger-tec!
Postby arranj » Tue May 10, 2011 8:58 pm
Fuel filter?
Re: Badger-tec!
Postby tourettes tony » Tue May 10, 2011 9:04 pm
yeah that will need doing as well :(
Badger-tec!
Postby arranj » Tue May 10, 2011 9:18 pm
Needs a new pump too. Carl already has that
Re: Badger-tec!
Postby Peter Filsell » Tue May 10, 2011 9:25 pm
Carlos,
Providing I can get my own jobs done, I'll be there! ;)
Peter Filsell
FIL675
Vin #1772
Peter Filsell
VIN #: 1772
Re: Badger-tec!
Postby Dan 6511 » Tue May 10, 2011 9:38 pm
If we can get the parts we can all all that in a day easily. Don't worry Carl you'll still make it to Belfast.
Re: Badger-tec!
Postby A Van » Tue May 10, 2011 9:38 pm
Ok , Jason just got off phone, he has offered to strip out his fans and cowling and I will drive over to collect on Friday or Saturday.
Sunday 15th May
Dereham, Norfolk
Bozzy, Al, Dan, Carl confirmed, Pete (maybe)
Radiator - In stock
Fans - In stock - Jason Monk - AV to collect
Cowling - In stock - Jason Monk - AV to collect
Carl, undo and take off one of the hoses on the bottom of the radiator and remainder of the coolant will drain out, take one of the jubilee clips off and take to a motor factors and buy 6, as Jason pointed out they prob wont go back on again properly.
Re: Badger-tec!
Postby arranj » Tue May 10, 2011 9:44 pm
So I send Carl a fuel filter? y/n?
what about a fuel pump boot? (if you change the pump - he already has a pump)
Re: Badger-tec!
Postby Dan 6511 » Tue May 10, 2011 9:47 pm
I can most likely russell up jubilee clips for you carl. Can't guarantee stainless ones but ill do my best.
Re: Badger-tec!
Postby carl hammond » Tue May 10, 2011 10:06 pm
OK, that's excellent, I'll get to work! 8-)
Arran, if you can send the fuel filter and parts for the fuel pump setup that would be great and we'll see how big these other jobs are before deciding whether to tackle them. I'm firmly going on the motto of "if it ain't broke, don't fix it" and the rad and fans definitely do need fixing!
That said, is there anything else I would need if we were to get round to replacing the fuel pump, someone mentioned about a pickup hose, or failing that just wedging a spring in there to support the original one?!
Whilst I think about it, does somebody have the specialist tool for removing the sump plug to do an oil change? From memory, I think it's an 8mm square socket?
Dan, let me know if you do have those clips, we've got a motor factors just down the road if needs be.
Thanks again guys.
Re: Badger-tec!
Postby A Van » Tue May 10, 2011 10:10 pm
Yes I have the tool, does it need changing desperately?
See if you can get some cardboard for lying on, spillages etc.
