DPNW poly bushings for ARB - LCA
Postby jerzybondov » Wed Jun 17, 2009 11:03 am
I've found out my front poly bushings on the ARB - frame joint (from Superflex, bought but not yet installed) aren't ideal as they don't have the dome fitting shape to make them properly snug. So I'm going to order a set of Toby's poly bushes which everyone raves about.
Now I can either just order the bushings I need for $65, or the lot for $100. When you take the shipping into account it makes sense for me to get all of it and then if anyone wants a set of LCA - ARB bushings (4x) then I can sell them to you for the extra it cost me - which will be much less than buying a set yourself from the States. I imagine I'd want about £40.
Any takers? Let me know quick as I want to place the order today! :D
Re: DPNW poly bushings for ARB - LCA
Postby A Van » Wed Jun 17, 2009 1:19 pm
Hi Gez
Can you wait until tomorrow, someone might come on tonight and want to go in with you?
Postby bozzzydmc » Wed Jun 17, 2009 1:29 pm
I agree with Al im sure someone will have them but more people will see this post this evening.
If it was me i would just go with it, you should find a buyer for these fine things matey .
Postby arranj » Wed Jun 17, 2009 1:31 pm
I would say go for it anyway, then put a listing in the "for sale" section, maybe for a bit more than you suggest including postage..... ;) With summer upon us (soon!) someone is bound to take them off your hands.
Postby jerzybondov » Wed Jun 17, 2009 2:10 pm
I hadn't heard anything and being a bit short on cash I just ordered the bits I need - but with this effusive feedback I've just emailed Misty to ask if I can have the full set rather than just the fronts...
I've also asked if they can do a John Hervey-esque '$10 Used car parts' on the box, makes life a lot easier this end! (Still not sure if they will though).
Postby mnickels » Wed Jun 17, 2009 7:34 pm
I replied on the other forum but probably a bit too late :(
Postby A Van » Wed Jun 17, 2009 9:30 pm
I think you might be ok Matthew...Gez?
Postby jerzybondov » Thu Jun 18, 2009 10:35 am
Not too late Matthew - you're in! Let me work out how much I need to charge but it'll be much less than the cost of importing them yourself...
Cheers!
G
Postby Admin-bloke » Thu Jun 18, 2009 12:54 pm
It is a very good kit, I recommend it !
Postby jerzybondov » Fri Jul 03, 2009 10:38 am
Does anybody know off the top of their heads what size socket I'll need to undo the nuts on the back of the LCAs that hold on the ARB? It's bigger than the 17mm I've got!
Cheers!
