Grey Passenger seat & lots of other DMC goodies for sale
Postby bigglesdmc » Fri Sep 02, 2011 12:38 pm
Passenger seat complete with new grey cover - perfect condition. Note - does not have the rear panel. - £200
2 x new grey lower seat covers - £50 each
1 x used grey seat cover set - not including back plate. Good clean condition with no tears or scuffs. Just 2 small areas need the stitching redone - about 50mm long each on lower seat section - £75
1 x front nose cone - needs repaint but good shape - £175
1 x exhaust in good condition - £100
2 x front indicator orange plastic housings - good condition - £20 pair
2 x front callipers - good condition for rebuild - £80 pair
Front wire grill, good condition - £30
Front brake disc - new x 1 only - £30
2 x new front hub / bearings, no studs included - QWB 244 ref - £60 pair
Set of 4 original headlamps and holders in good order - £40
1 x air con compressor - believed good - £80
2 x exhaust manifolds with front pipe good - £100
Main engine harness - £80
4 x door struts, 2 bonnet struts, 2 engine cover struts - all seem good used items - £60 lot
Set of front and rear wheel arch filler pieces (that go between the body tub and the stainless panels - £30
Handbrake cables x 2 - used condition - £30 pair
New distributor cap and rotor arm - £20
2 front and 2 rear brake hoses, new - rubber with coil of wire on rear, coil of plastic on front - £40 for all
I will consider an offer for all parts, and will chuck in all the various other odds and sods I have.
Post will be on top and we can discuss as you need bits. Alternatively pick up from near Chippenham, Wiltshire UK
Phone Andy on 01249 783305 or email andy@theonetocall.com
bigglesdmc
Re: Grey Passenger seat & lots of other DMC goodies for sale
Postby delorean12uk » Fri Sep 02, 2011 4:50 pm
bigglesdmc wrote:2 x front callipers - good condition for rebuild - £80 pair
you can pick them up fully refurbed for that price!
Postby bigglesdmc » Fri Sep 02, 2011 5:19 pm
I didn't know that! In that case £20 pair for the callipers! I need to move this stuff on but need the money as well! So please make realistic offers if you spot something like this - I'm not out to rip anyone off!
bigglesdmc
Postby dmc4087 » Fri Sep 02, 2011 8:57 pm
What vin is the engine loom from?
Postby Dan 6511 » Fri Sep 02, 2011 9:54 pm
Is that the exhaust you bought off me on ebay?
Postby bigglesdmc » Sat Sep 03, 2011 8:55 am
Hi - I'm afraid I don't know which engine the loom is from as I bought it a while back as a spare. I can take a photo of it if that helps.
bigglesdmc
Postby bigglesdmc » Sat Sep 03, 2011 8:57 am
Yes it is the same exhaust - still in great shape and I should add that it has the stainless steel bits on the end of the pipes.
bigglesdmc
Postby Admin-bloke » Sat Sep 03, 2011 1:39 pm
Good luck with the sale.
Could you confirm if the hubs are brand new hubs with new bearings already pressed in please. Thank you.
Postby bigglesdmc » Sat Sep 03, 2011 4:18 pm
Hubs are brand new with bearings pressed into position - I can send a photo if it helps.
bigglesdmc
