Illuminated LED door sills UPGRADE
Postby ALEXAKOS » Fri Jun 20, 2014 6:24 pm
After having made my own set, I had a couple requests from over the pond since DMCMW is no longer offering them.
So I created a total of 14 sets
SEVEN sets DELOREAN
AND SEVEN DMC
One set includes :
- 2X stainless brushed plates on white plexiglass. (plexiglass may be ordered in different color e.g. blue red etc)
- 2X 20cm led 10W bars wired, with 3M adhesive strip for mounting on the rear of the sill .
- 4X wire clips
Pricing: 178USD Shipped with tracking world wide.
Installation: (NEEDS SOME SKILLS)
-Cut around the edges of the existing DMC letters
Soft strokes at first, harder second passes.
- Apply two component epoxy glue around the cut frame
- Set onto the given space the plates. They are a perfect fit. Can't go wrong. And apply pressure for at least an hour.
(don't mind this photo's missing pieces on the "a" "e" and "o"'.)
- Turn over sill, remove the LED's strip 3M adhesive foil to stick it on to the rear top section of the small frame. The LED should be facing flat down when the sill will be sitting on your car.
- Remove the black protective vinyl center section from your rocker support. Polish off the glue residue and make it shinny.
Needs to be shinny to reflect the light from the led.
- Now place the sill back onto the rocker support. Do not press it down. You will need to push each tooth into place carefully not to push off the clips.
Finally connect the wires to any door ajar lighting power source. Wires are long enough to reach both dash and or rear compartment.
Enjoy your fancy Door sills.
Re: Illuminated LED door sills UPGRADE
Postby RobvdVeer » Fri Jun 20, 2014 7:11 pm
Now, back to restoring your car to make it driveable!
Postby ALEXAKOS » Fri Jun 20, 2014 8:34 pm
Hehe! Patience. As tv stations need funds through advertisements, likewise I need to promote my stuff to support my restoration;)
Postby ALEXAKOS » Wed Jul 02, 2014 12:27 pm
There is a 522 VIN in the UK with a red interior.
So the new owner ordered a RED door sill plates set.
Looks sexy! I bet that RED INTERIOR delorean will look awesome//
CHEERS MATE
Postby arranj » Wed Jul 02, 2014 12:42 pm
viewtopic.php?f=56&t=2076
Although it's been restored (and sold twice) since then!
Postby ALEXAKOS » Wed Jul 02, 2014 12:51 pm
arranj wrote:http://www.deloreaneurotec.co.uk/forum/viewtopic.php?f=56&t=2076
Great Arran.;)
Spencer will be pleased to see that.... I hope.
Users browsing this forum: No registered users and 50 guests
