used Kjetronic parts
Postby delorean12uk » Wed Oct 26, 2016 7:10 pm
I'm sitting on quite a lot of K jetronic parts mainly from the B28E variant of the PRV6, but a lot of it is compatible.
I have metering heads, plenuim chambers, throttle bodies.
OEM fuel lines, Banjo bolts, control pressure regulators, auxiliary air valves, injector seals and clips
Injectors go to Admin to be tested, so see him if you need any
They are all used parts but came from running vehicles
All at very reasonable prices
banjo bolts.jpg (100.45 KiB) Viewed 4108 times
injector seals.jpg (107.36 KiB) Viewed 4108 times
Injectors seals and clips.jpg (240.57 KiB) Viewed 4108 times
plenium chamber and throttle body.jpg (216.78 KiB) Viewed 4108 times
If you need anything just PM me
Re: used Kjetronic parts
Postby Admin-bloke » Wed Oct 26, 2016 7:29 pm
Great that you've kept hold of these Jay, nice one!
I can overhaul and calibrate your CPR's if you like (Delorean oem and the volvo specific ones too) and make as many good ones as possible from your spares. I'll just reserve a day in the garage and fix them like a production line. Just let me know.
Postby delorean12uk » Wed Oct 26, 2016 9:38 pm
Okay Nicky honey, I'll mail a consignment of bits to you soon x
Postby jamesrguk » Sun Oct 30, 2016 10:04 am
Those ribbed injector seals are so much better than the oem ones, but where did you get them?
Postby delorean12uk » Tue Nov 01, 2016 8:44 am
The engine I sold you James
