40 DMC Parts (17 new/23 used) some are rare items end 14/02
Postby Chris Hawes » Sun Feb 07, 2021 6:48 pm
I’m having a clear out of new/used parts. Some of these parts (new and unused) are no longer available from any of the vendors. All of the items finish in the evening of Sunday 14th February GMT. Shipping is free to all UK buyers. International buyers are welcome, but please contact me before bidding so that you’ll know what your shipping rate will be.
New
111388 Hood Edge Strip 44" –Side
https://www.ebay.co.uk/itm/164686042882
111389 Hood Edge Strip 59" – Top
https://www.ebay.co.uk/itm/164686043971
105542 Brake Servo OEM New
https://www.ebay.co.uk/itm/164686045068
100289 Stainless Brake Servo Booster Mounting Bracket
https://www.ebay.co.uk/itm/164686045644
108534 The DeLorean Go Silicone Rubber Door RH Fixed Glass Perimeter Seal
https://www.ebay.co.uk/itm/164686046998
108533 The DeLorean Go Silicone Rubber Door LH Fixed Glass Perimeter Seal
https://www.ebay.co.uk/itm/164686047779
108205 accelerator pedal cover only
https://www.ebay.co.uk/itm/164686054239
106130 angle drive
https://www.ebay.co.uk/itm/164686054719
108737 hood seal
https://www.ebay.co.uk/itm/164686055873
SP10497 INNER DOOR SEAL EDGE CLIP
https://www.ebay.co.uk/itm/164686057896
106781 No Drip Tape
https://www.ebay.co.uk/itm/164686058941
100701 LH OEM NEW belt and OEM NEW receptacle inc OEM NEW plastic cover
https://www.ebay.co.uk/itm/164686060176
100702 RH OEM NEW belt and OEM NEW receptacle inc OEM NEW plastic cover
https://www.ebay.co.uk/itm/164686064308
105085 OEM EXTERIOR MIRROR ADJUSTMENT SWITCH
https://www.ebay.co.uk/itm/164686067587
108209G PJ Grady Gas Strut - Louvre (single)
https://www.ebay.co.uk/itm/164686068393
105257 Rubber boot for lower ball joint/tie rod end/track rod
https://www.ebay.co.uk/itm/164686069011
Used - All of the below are original OEM 1981 parts from an Oct 1981 build
100181 11 used OEM wheel nuts
https://www.ebay.co.uk/itm/164685865497
100701 LH OEM belt used and NEW OEM receptacle not inc plastic cover
https://www.ebay.co.uk/itm/164685872895
100702 RH OEM belt used and NEW OEM receptacle not inc plastic cover
https://www.ebay.co.uk/itm/164685874595
110416 Mirror glass
https://www.ebay.co.uk/itm/164685879588
110520 Fuse Box Cover
https://www.ebay.co.uk/itm/164685885582
101064O Original (Black) RPM relay
https://www.ebay.co.uk/itm/164685888561
106720 RH REAR SPEAKER BRACKET
https://www.ebay.co.uk/itm/164685900516
106721 LH REAR SPEAKER BRACKET
https://www.ebay.co.uk/itm/164685896916
108748 OEM grooved ash tray
https://www.ebay.co.uk/itm/164685920726
108288 OEM Cigar Lighter complete with illuminated ring
https://www.ebay.co.uk/itm/164685924396
110523 Console Cover grey
https://www.ebay.co.uk/itm/164685928433
110521 Console Tray grey
https://www.ebay.co.uk/itm/164685930951
105104 Speedometer Drive Dust Shield
https://www.ebay.co.uk/itm/164685966449
101440 STORAGE (CUBBY BOX) LOCK
https://www.ebay.co.uk/itm/164685942707
105610 Dummy Switch pair
https://www.ebay.co.uk/itm/164685944319
https://www.ebay.co.uk/itm/164685944911
101488 Tail Light Boards with Incandescent Bulb Kit
https://www.ebay.co.uk/itm/164685970285
100169O OEM drive shaft
https://www.ebay.co.uk/itm/164685971406
118702 Rear wheel (hub area needs repair)
https://www.ebay.co.uk/itm/164685986378
101044 OEM Starter Motor
https://www.ebay.co.uk/itm/164686006120
100462 Clutch Master Cylinder DMC
https://www.ebay.co.uk/itm/164686009559
110085 OEM Fuel Pump Bosch
https://www.ebay.co.uk/itm/164686011679
108683 Fuel Tank Baffle Outer Retainer Spring
https://www.ebay.co.uk/itm/164686016830
100817 Lamp Delay Unit
https://www.ebay.co.uk/itm/164685948670
If you have any queries, please message me via the listing on eBay.
Best wishes
Chris
Regards,
Chris Hawes
Chris Hawes
VIN #: Ex owner of 5255
Re: 40 DMC Parts (17 new/23 used) some are rare items end 14
Postby arranj » Sun Feb 07, 2021 11:30 pm
Some of your items you are claiming to be "The DeLorean Go...." etc., don't at first glance appear to be so... Are you sure on the history on some of these items? especially those which are in DMCH bags? - i.e. the window seals etc. The "hood" seal certainly isn't a "DeLorean Go" seal in any way at all.... :) - and the fixed glass seals look more like an OEM seal to me (and actually have a DMCH sticker on them). Possibly makes them worth more to some people ;)
Postby Chris Hawes » Mon Feb 08, 2021 9:55 am
Thanks Arran, personally I believe DeLorean Go carries more kudos these days. Thanks for the heads up, I've corrected those listings. The DMCH parts were bought long before DeLorean Go existed...
Regards,
Chris Hawes
Chris Hawes
