33 DMC Parts (15 new / 18 used) some are rare items, auction
Postby Chris Hawes » Wed Feb 24, 2021 10:50 pm
33 DMC Parts (15 new / 18 used) some are rare items, auctions end Sat 6th March 21
I’m having a clear out of new/used parts. Some of these parts (new and unused) are no longer available from any of the vendors. All of the items finish in the evening of Saturday 6th March GMT. Shipping is free to all UK buyers. International buyers are welcome, but please contact me before bidding so that you’ll know what your shipping rate will be.
New
111388 Hood Edge Strip 44" –Side
https://www.ebay.co.uk/itm/164722503367
111389 Hood Edge Strip 59" – Top – SOLD
105542 Brake Servo
https://www.ebay.co.uk/itm/164722504213
100289 Stainless Brake Servo Booster Mounting Bracket
https://www.ebay.co.uk/itm/164722505098
108534 The DeLorean Go Silicone Rubber Door RH Fixed Glass Perimeter Seal
https://www.ebay.co.uk/itm/164722505529
108533 The DeLorean Go Silicone Rubber Door LH Fixed Glass Perimeter Seal
https://www.ebay.co.uk/itm/164722505972
108205 accelerator pedal cover only
https://www.ebay.co.uk/itm/164722506751
106130 angle drive
https://www.ebay.co.uk/itm/164722507541
108737 hood seal
https://www.ebay.co.uk/itm/164722508116
SP10497 INNER DOOR SEAL EDGE CLIP
https://www.ebay.co.uk/itm/164722509032
106781 No Drip Tape
https://www.ebay.co.uk/itm/164722509919
100701 LH OEM NEW belt and OEM NEW receptacle inc OEM NEW plastic cover
https://www.ebay.co.uk/itm/164722514206
100702 RH OEM NEW belt and OEM NEW receptacle inc OEM NEW plastic cover
https://www.ebay.co.uk/itm/164722514986
105085 OEM EXTERIOR MIRROR ADJUSTMENT SWITCH
https://www.ebay.co.uk/itm/164722515536
108209G PJ Grady Gas Strut - Louvre (single)
https://www.ebay.co.uk/itm/164722515929
105257 Rubber boot for lower ball joint/tie rod end/track rod – SOLD
Evaporator Protector Mesh
https://www.ebay.co.uk/itm/164722517566
Used - All of the below are original OEM 1981 parts from an Oct 1981 build
100181 11 used OEM wheel nuts
https://www.ebay.co.uk/itm/164722518118
100701 LH OEM belt used and NEW OEM receptacle not inc plastic cover
https://www.ebay.co.uk/itm/164722518454
100702 RH OEM belt used and NEW OEM receptacle not inc plastic cover
https://www.ebay.co.uk/itm/164722518745
110416 Mirror glass – SOLD
110520 Fuse Box Cover – SOLD
101064O Original (Black) RPM relay – SOLD
106720 RH REAR SPEAKER BRACKET
https://www.ebay.co.uk/itm/164722519034
106721 LH REAR SPEAKER BRACKET
https://www.ebay.co.uk/itm/164722519457
108748 OEM grooved ash tray
https://www.ebay.co.uk/itm/164722520460
108288 OEM Cigar Lighter complete with illuminated ring
https://www.ebay.co.uk/itm/164722521096
110523 Console Cover grey
https://www.ebay.co.uk/itm/164722521937
110521 Console Tray grey
https://www.ebay.co.uk/itm/164722522716
105104 Speedometer Drive Dust Shield – SOLD
101440 STORAGE (CUBBY BOX) LOCK – SOLD
105610 DeLorean DMC-12 OEM Pair Of Dummy Switches
https://www.ebay.co.uk/itm/164722523546
https://www.ebay.co.uk/itm/164722524029
101488 Tail Light Boards with Incandescent Bulb Kit – SOLD
100169O OEM drive shaft
https://www.ebay.co.uk/itm/164722524911
118702 Rear wheel (hub area needs repair)
https://www.ebay.co.uk/itm/164722525842
101044 OEM Starter Motor – SOLD
100462 Clutch Master Cylinder DMC
https://www.ebay.co.uk/itm/164722526200
110085 OEM Fuel Pump Bosch
https://www.ebay.co.uk/itm/164722527057
108683 Fuel Tank Baffle Outer Retainer Spring
https://www.ebay.co.uk/itm/164722533865
100817 Lamp Delay Unit
https://www.ebay.co.uk/itm/164722534469
7701499465 Renault Alternator
https://www.ebay.co.uk/itm/164722546718
Back To The Future related items
AOSHIMA Amerang motorised Back To The Future Part 3 DeLorean – Built
https://www.ebay.co.uk/itm/164722577123
Back To The Future – SMITHS – Board Game 1985
https://www.ebay.co.uk/itm/164722651429
Aoshima Back To The Future Part 1 DeLorean 1:24 Scale (incomplete)
https://www.ebay.co.uk/itm/164722594983
Aoshima Back To The Future Part 2 DeLorean 1:24 Scale
https://www.ebay.co.uk/itm/164722596116
Aoshima Back To The Future Part 3 DeLorean 1:24 Scale
https://www.ebay.co.uk/itm/164722597217
Halcyon Back To The Future Part 2 DeLorean 1:24 Scale
https://www.ebay.co.uk/itm/164722598122
Halcyon Back To The Future Part 3 DeLorean 1:24 Scale
https://www.ebay.co.uk/itm/164722598592
If you have any queries, please message me via the listing on eBay.
Best wishes
Chris
Regards,
Chris Hawes
Chris Hawes
VIN #: Ex owner of 5255
Re: 33 DMC Parts (15 new / 18 used) some are rare items, auc
Postby eric » Thu Feb 25, 2021 9:47 am
You upping sticks and fleeing the country or downsizing ?
Postby Chris Hawes » Thu Feb 25, 2021 9:54 am
Hi Eric,
I've gathered way to much over the years, plus the parts I'm selling I'm never going to need so may as well make them available for others to benefit from.
Regards,
Chris Hawes
Chris Hawes
