Thanks for the advice, the screw is back on position.
The engine start and idle at 900rpm
I drove around 15 minutes and it goes up to 1500 rpm
So, I need to drive it more and adjust it a little bit.
Nevertheless, it will take some time...
Just because, like my old cruising, I came back home with a problem!
This time I was able to drive the car back home just in time.
When I was driving, at around 5000 rpm, I was unable to change gear.
I locked the second gear to reach home, then no more first gear or reverse.
I think my clutch is dead, it smell burn...
Needless to say I'm a little bit disappointed.
I spent 2 year working on the car and was hoping to drive it, now the sun is here, but no.
I wonder if I may be able to do it myself with my own tools, I need space and I don't know if the height will be enough.
I think I need to take a break and get back some strength to work on the car again and again...
- DSCN4452.JPG (58.56 KiB) Viewed 3872 times
- DSCN4453.JPG (72.64 KiB) Viewed 3872 times
