Hello,
New rad went in before OctoberTec. No leaks for now, lets see how this one lasts.
Also, just because I was at it, a new condensor and split hoses. Replacing the hoses is possible. But like most jobs, not entirely fun...
Once the weather merits it, I will commission the AC system. Bar the evaporator core, and compressor, it will be new...
In October, NickT reckoned my slightly rough running was likely the accumulator. I hadn't touched it in 11 years... And pretty sure the PO wont have been doing it ...
A good place to start after Nick's help with initial diagnosis, and a right of passage for Delorean owners along with fuel pumps, hoses, TABs, LCAs and angle drives.
So I had to leave it a couple of months after buying, such that the pain of opening my wallet for a nice new German accumulator subsided:
- 20230128_111300[1].jpg (1.66 MiB) Viewed 25324 times
And I cut down (shittest!) 17mm and 19mm spanners, to crack off the unions before removing the clamp:
- 20230128_121326[1].jpg (3.57 MiB) Viewed 25324 times
Hateful, but now for the impossibly hard 18th century hoses. Trying to get the cunting accumulator out its nest, I couldn't even get through them with snips. Stanley wasn't quite up to it either...
Unions off. Accumlator out, and eventually get the small tail of the accumulator off the return plastic hose. Stanley to scratch away at old hoses on the return hardline. Ugh... Finally:
- 20230128_132954[1].jpg (3.21 MiB) Viewed 25324 times
My new least favourite job on the car must be lying on your back, working in a hole big enough for 1 hand, working by feel only, to hold up a fucking heavy object AND get a bolt in... Thinking about it now, I should have got a stick or similar, or tried to be a bit more creative, but Victory was snatched from the jaws of Defeat:
- 20230128_152220[1].jpg (3.28 MiB) Viewed 25324 times
And I am very fucking pleased to say it appears to have cured the rough idle for first wee while, poor starting, bit sluggish when WOT (heh! They all do that sir...) So thanks a million Nick, diagnosis was spot on.
Less pleased about the distinct whiff of fuel if you park up... No drips and feels dry, but cant get a look. Will be going back under to see where the weep is. Maybe when I do the angle drive, which also failed recently of course. I think this failure was due to the fact the front left wheel having turned, this causing the internals to explode again.
I want a Speedhut Speedbox, but am not quite up for the wallet bit. Have a fucking great GPS speedo solution on an old bike, works a treat and is very discreet.
