VIN 5257 Maintenance thread
Re: VIN 5257 Maintenance thread
Postby Azar » Mon May 25, 2020 8:09 pm
Following has been done at DMC Houston:
1. K111143A Major Service Kit (4 Year 30,000 Miles)
2. K118674 Complete Hose Kit - (they installed only in the motor compartment, the rest I will install myself).
3. 107000 Fuel Pump and Sender Module and tank cleaning
4. 73010 REBUILD A/C MODE CONTROL SWITCH (BENCH JOB)
5. 102462 OIL PRESSURE SENSOR (LIGHT)
6. 100408 REAR SHOCK (PAIR)
7. 102807 REBUILT FUEL DISTRIBUTOR
8. 102353 WARM-UP / CONTROL PRESSURE REGULATOR
9. K102318A BRAIDED STAINLESS FUEL LINES (BLACK - SET OF 9)
10. 100462 CLUTCH MASTER CYLINDER
These parts already here and I will install them::
1. GT100200 Performance Air Intake.
2. 101994 BUSHING, STRG COLUMN
or do I need this: Delrin Steering Column Internal Bushing https://www.deloreango.com/de/steering- ... shing.html
The steering column is moving up/down :(
Following parts will be ordered from Deloreango.com:
- K111592B Struts Set
- 12x 106272 SCREW, REAR TAIL LAMP
- 2x 111128 The DeLorean Go Silicone Rubber Outer Door Seal (1 COMPLETE DOOR)
- K111096 Decal / Label Set
- Reproduction Wide Dealer Side Stripe with 3D DMC Logo (full set)
- 106931 Stainless Exhaust Heat Shield
…and Delorean.eu:
- 101601 Left Black Headlight Gap Finisher
Brakes
- 109040A 50:50 Brake Master Cylinder
- (2) 109000 Caliper Rebuilt Kit (Front)
- (2) 109006 Caliper Rebuilt Kit (Rear)
- 109005A Front Brake Pads (complete set of 4)
- 109012A Rear Brake Pads (complete set of 4)
- K100095 Front Brake Discs (PAIR)
.......a. or vented for 213 Euro
- 100252 Rear Brake Discs (PAIR)
For the German TÜV I need lights and tyres. The aftermarket lights are cheap at 70 Euro all 4. The Hellas are 4 times more expensive
- Front - 195/60 R14 - easy to find
- Rear - 235/60 R15 - almost impossible?
Azar
VIN #: 05257
Postby eric » Tue May 26, 2020 2:37 pm
Rear tyres are rare but they are still made.
I took a chance with a company I had never heard of and they were fine.
This was from 2018, I think they came all the way from Spain.
Items ordered:
Pirelli P600 235/60R15 98 W Quantity: 2 x 204,00 GBP
Order status: Parcel has been shipped
In urgent cases relating to the order, you can contact us by e-mail, responding to the automatically generated confirmation message.
E-mail: info@oponeo.co.uk
Yours sincerely, Team OPONEO.CO.UK.
Looks like they don't have the Pirelli's there now.
https://www.oponeo.co.uk/tyre-finder/s= ... 235-60-r15
Cooper Cobra ?
Postby Azar » Tue May 26, 2020 2:41 pm
Thanks! I did not really want those R/T , M+S all weather tyres. They are terrible in wet. And not available for the front. Probably go with 225 60 15 like most of owners in Germany and get it homologated.
Azar
VIN #: 05257
