Postby Domi » Mon May 30, 2016 5:39 pm
By the way, thank you very much for the awesome sticker :thumbsup:
It will be great on the windshield or the rear side window :dance:
Postby A Van » Mon May 30, 2016 8:03 pm
Thanks Domi, Rissy also likes his sticker on the rear side window
Postby Domi » Sat Jun 04, 2016 6:38 pm
Well, I have tried to restart the engine today, no luck
The engine start but stalls after a few seconds (see video)
https://youtu.be/EFbsw2YaxpE
The fuel lines of the pump are correct, tried to invert them and the pump make a weird noise…
On the other hand, I had a leak on the top of the fuel filter, even with new copper seal…
No more leak elsewhere.
I will try to start it again tomorrow, but I have to find what is going on now?...
Postby Admin-bloke » Sat Jun 04, 2016 7:49 pm
Fix the leak first then retry.
The video indicates that it is trying to start and may be from the fuel from the cold start injector.
The video does positively show that the frequency valve is buzzing and shows that the fuel pump relay is in operation.
You could try the old method of:
Disconnect blue plug from the cold start valve
Disconnect grey plug from the CPR and plug this into the blue cold start valve
Try and start the engine again
Good luck, almost there
EDIT: Corrected auto correct word replacements.
Postby andyd » Sat Jun 04, 2016 8:03 pm
Admin-bloke wrote:the girl pinko roast is in operation
Now that's an operation I'd like to see! !
Postby Domi » Sat Jun 04, 2016 8:11 pm
Thanks Admin-bloke for all the good advices, I'll try tomorrow ;)
Postby Admin-bloke » Sat Jun 04, 2016 9:00 pm
Edited original post to correct auto correct word replacements due to mobile phone screen protector. .. !!!
Postby Admin-bloke » Sat Jun 04, 2016 9:01 pm
Domi wrote:Thanks Admin-bloke for all the good advices, I'll try tomorrow ;)
Good luck Domi
Postby Domi » Sat Jun 04, 2016 9:09 pm
Thank You ;)
Postby A Van » Sat Jun 04, 2016 10:17 pm
Me too!!
