Postby Admin-bloke » Fri Mar 29, 2013 6:43 pm
Sounds like an impressive spec there and I'd love to see that sexy looking engine on the rolling road !
Postby Kenny » Fri Mar 29, 2013 6:43 pm
Starglider wrote:Removable goose-neck tow bar (with multi-point stainless support structure).
Stainless door handles
Rear sway bar, mounting to hubs, routed through cradle tunnel (Martin G)
Annoying warning buzzer replaced by Pontiac chime module, with silencer switch
Stainless electroluminescent headlier logos
Stainless rear spoiler
That is a serious build list! Not sure if the above were mentioned elsewhere. Would love more info or pics of them
Kenny
VIN #: 1569
Postby Starglider » Fri Mar 29, 2013 7:11 pm
Kenny wrote:That is a serious build list! Not sure if the above were mentioned elsewhere. Would love more info or pics of them
This is the chime module, came from Germany strangely;
I haven't finnished the socket adapter to wire it neatly yet, I'm following the guide Welmeod posted on DMCtalk (but with an extra switch to turn it off completely).
Tow bar is a Towsure unit originally designed for the Toyota Yaris;
Chris is working on the mounting spider for it, he thinks it can bolt on without needing any frame modifications.
The headliner logos look exactly like the sill logos;
but with a thin border of stainless visible instead of the whole plate. I actually made them because I had some spare logo plates left over (ordered them before I decided to get the ready-made light-up sills). All the logos are grounded through the door switches but powered from the 'aux lighting' center console switch, so they only come on when the appropriate door is open and aux lighting is enabled.
I keep forgetting to take photos, sorry will try and remember next time I'm down at Chris's workshop.
Starglider
VIN #: 12306
Postby dmc4087 » Sat Mar 30, 2013 12:06 am
Why do you want it as a 2013 Delorean? Would you not be liable for more tax etc? I see they might count it as a 2013 delorean but I cant see enthusiasts viewing that way (ie wasnt built in the factory)
Sounds like a beast though, twin turbo will be sweet.
The fibre glass fascia still seems nuts to me :p
Postby Starglider » Sat Mar 30, 2013 2:56 am
dmc4087 wrote:Why do you want it as a 2013 Delorean?
I don't, it's more hassle (for insurance, forums etc) and more expensive, although on the plus side it does seem more honest. This is simply what the DVLA recommended and as such the best chance to get the car registered promptly and legally.
The history and context of the car, like all mass produced items, is embodied in the design, all the people and work that went into making that design a reality, and the lingering cultural impact. The history of when any given set of parts was bolted together into a car is trivia by comparison; there are a few DMC-12s with individual historic notability but the vast majority of examples are just that, examples of the design. Obviously a lot of people imbue objects with a mystical capability to contain history, and I can understand that for one-of-a-kind masterpieces, objects that played a pivotal role in wars or politics, even movie props, but for a typical assembly line motorcar I'm not feeling it.
So in short it's blatantly obvious that anything built in 2013 isn't an original DMC product (including everything made by DMC Houston), I don't care and I'm actually glad that this will be plainly stated on the V5. I'd rather be honest and annoy purists than misrepresent the car or the huge amount of sterling work done by Chris & Ed.
Starglider
VIN #: 12306
Postby Admin-bloke » Sat Mar 30, 2013 10:11 am
Fwiw I'm seeing this car as a 1985 improved car if the development continued and look forward to seeing the engineering that has gone into it, especially the engine :D
Postby jerzybondov » Sat Mar 30, 2013 3:39 pm
AMAZING spec! Can't wait to see it come together...
Postby Starglider » Sat Mar 30, 2013 5:31 pm
Thanks for the encouragement guys, with luck it will be ready for at least one event this summer.
Manxmann wrote:So you going to need a 'completely' separate hydraulic line and callipers to achieve this, is it really worth all the hassle? How are you going to modify the rear hubs for the 2nd calliper?
Honestly I have no idea, Martin advertises the brake upgrade as 'fully fitted' so I assume he has a plan, but I don't know the details. Ed Uding has apparently been working on a fully compliant four wheel brake upgrade kit, but hasn't had the time to complete it.
Starglider
VIN #: 12306
Postby Starglider » Tue Apr 02, 2013 5:00 pm
Mid-80s appropriate seatbelt covers (i.e. if the car has a turbocharger, plaster 'turbo' on every free surface);
Starglider
VIN #: 12306
Postby A Van » Tue Apr 02, 2013 6:14 pm
Nice touch!
