vin 814
Re: vin 814
Postby A Van » Mon Apr 27, 2015 8:14 pm
Great work Andy, you have really turned that car around mate
Re: vin 814
Postby Admin-bloke » Mon Apr 27, 2015 9:07 pm
Wow, a lot of effort there. Keep up the good work
Re: vin 814
Postby andyd » Tue Apr 28, 2015 12:50 am
Thanks for the encouragement gents. These threads are quite useful to keep track of what's been done.
Al, I thought of you sweetly as I fitted that hose. Mmmm! Silicone!
Today I chased down coolant leaks and cursed the handbrake pads which broke up. The resultant enormous slack in that cable caused the other to pop off. Fabulous design!
emergency brake as the yanks call it?? :lol: I would hate to have to rely on it!
One side fails, and causes the other side to fail too? how quaint!
A
Re: vin 814
Postby andyd » Fri Jun 19, 2015 3:21 pm
MOT obtained today! :D Handbrake adjusted as per Darren's post. As recommended, I got circular adhesive sanding disks and stuck one to each face of the rear disks.
viewtopic.php?f=21&t=4125&hilit=handbrake+pads#p54651
I then used this to grind the pads to fit. Didn't take much, but was so successful that it even passed on the rollers. No hookey MOT pranks necessary.
Front headlights needed adjustment, but that is probably after the suspension rebuild. (And it did drop a bit of coolant, due to a hoseclamp needing nipped). But all good!
Alignment tomorrow. 8-)
This kind of makes all the crap worthwhile!
cheers
andy
Re: vin 814
Postby MikeWard » Fri Jun 19, 2015 3:23 pm
Nice one Andy, when is it coming back down south?
Re: vin 814
Postby andyd » Fri Jun 19, 2015 3:35 pm
Soon! A month maybe? As long as no more automotive mishaps or other (ahem!) personal issues get in the way...
So finally, I will get to meet up with some other owners!! It has been a long time coming!
a
Re: vin 814
Postby A Van » Fri Jun 19, 2015 4:19 pm
V pleased for you mate, you have put a lot of work in
Re: vin 814
Postby andyd » Sat Jun 20, 2015 9:35 pm
Thanks Al,
Alignment done today at Hypertech Scotland.
I would recommend them to other guys with DeLoreans in central Scotland. They are in Bonnybridge, have the Hunter system, and know their stuff.
http://www.hypertechscotland.co.uk/
Hypertech
Unit 13
Bonnybridge Ind Estate ,
Murnin Road,
Bonnybridge,
Falkirk
FK4 2BW
Telephone : 01324 812 212
Fax : 01324 : 815 556
Of course the car is transformed. It no longer screeches with the slightest steering input, or skips under braking. I then spent the rest of the day tooling round back roads and enjoying the "public appreciation" in Glasgow! (twat). Fuelling seems good, gearchange & clutch are great, new fans, rad and hoses are doing the trick. Headliners and door trim are refreshed and back in, so I think the car's almost done.
Am back down south (on the train) tomorrow, but of course the symptoms of imminent angle drive failure mean that it will need a bit of investigation before heading off. Typical....!
a
Re: vin 814
Postby arranj » Sun Jun 21, 2015 12:26 am
andyd wrote:I then spent the rest of the day tooling round back roads and enjoying the "public appreciation" in Glasgow! (twat)
Best post ever :lol:
Re: vin 814
Postby A Van » Sun Jun 21, 2015 1:38 am
Yes!!
