Postby mnickels » Fri Apr 08, 2011 10:12 pm
A Van wrote:Sounds like shitty connection have you taken that connector of at the back and cleaned
No but fuse 5 only has 2V at it so possibly accessory relay but don't know what way it should be wired
Postby A Van » Fri Apr 08, 2011 10:16 pm
Mmmmm ok do your headlights work?
Postby Admin-bloke » Sat Apr 09, 2011 7:41 pm
I think the earth points all go to a crappy stud to the right of the stereo with it removed.
All earths ring terminals and the nut goes loose.
Do other circuits from the accessory relay work?
Postby bozzzydmc » Sun Apr 10, 2011 1:28 pm
Yes that is where they all terminate ... what a great feat of engineering it is to site them there ;)
One lttle nut comes loose and a whole raft of problems occurs ...
Just like the battery dash bulb :)
Postby KMC-DMC » Sun Apr 10, 2011 2:06 pm
Ahh yes, the genius that is DMC electrics. I relocated the console ground point to up near the vent so its easier to access.
Kevin
KMC-DMC
Ex owner of VIN 2969
London
KMC-DMC
VIN #: Ex 2969
Postby mnickels » Fri Apr 15, 2011 9:14 pm
Dash now working, although windscreen wipers on constant and power supply to "trunk" light is a short circuit.
A lot of work to do but hopefully having the next 2 weekends practically football free as well as easter, may day and royal wedding will get a lot of gremlins sorted and an MOT can be booked.
If anyone can help me with headlights it would be much appreciated. My local places don't do hella or valeo. I will Paypal ££ if anyone can help. Martin provided my last ones but standards instead of Halo will do.
Otherwise a fair bit of rebuilding to do in the interior as well as window motors not working...
Postby arranj » Fri Apr 15, 2011 10:22 pm
Dave H
Postby mnickels » Sat Apr 16, 2011 4:26 pm
Cheers Arran, will give him a call. When is the best time to get him?
Spent today sorting out the electrical gremlins. Still some to sort but started cleaning up the interior, put a temporary cover on the drivers seat and got my Craig radio pumping out the tunes. Drivers side carpets removed and cleaned as best as possible. I also fed the leather that is still usable to make it look a bit healthier. I am missing the carpet that goes behind the seats if anyone know where I can get this part only.
Is there a trick to getting the rubber that goes around the vents on correctly? They are out of shape as they were not fitted correctly when I removed them.
Off out for a well earned meal now and may head out to the garage again after.
Postby arranj » Sat Apr 16, 2011 4:33 pm
mnickels wrote:If anyone can help me with headlights it would be much appreciated
arranj wrote:Dave H
mnickels wrote:I am missing the carpet that goes behind the seats if anyone know where I can get this part only
arranj wrote:Dave H
No idea on times - he usually answers I think:
01942 882331 (mobile 07712 544291)
Postby Dan 6511 » Sat Apr 16, 2011 4:57 pm
Nice one mat, sounds good. Is the tub fully bolted down now? Any pics?
