Postby ALEXAKOS » Fri May 02, 2014 8:23 pm
getting there :)
Cant wait to see what this baby puts out on a dyno!
Postby jerzybondov » Fri May 02, 2014 11:45 pm
Looking great there. Nice louvre detailing too with the hook and stainless structure. How much heavier are the fibreglass fascias than the plastic ones? Difficult to get onto the car single handed I'd have thought!
Postby Starglider » Sat May 03, 2014 10:15 am
jerzybondov wrote:How much heavier are the fibreglass fascias than the plastic ones? Difficult to get onto the car single handed I'd have thought!
Fairly hefty but not a problem to lift & carry. I've been taking the back off and on again without an issue. I left the front to Chris as it's tricky to line up.
Starglider
VIN #: 12306
Postby jerzybondov » Sat May 03, 2014 4:29 pm
What are you planning to do re the rubber strip down the side of the car? Putting one on or leaving without?
Postby Starglider » Sun May 04, 2014 10:38 am
jerzybondov wrote:What are you planning to do re the rubber strip down the side of the car? Putting one on or leaving without?
I am working on a surprise for that but not sure how it will turn out, if it doesn't work will revert to the standard strip.
Starglider
VIN #: 12306
Postby OllieWilks » Sun May 04, 2014 2:06 pm
Looking very smart, come together nicely! :thumbsup:
http://www.deloreanhire.com
OllieWilks
VIN #: 3928, 3185
Postby Starglider » Fri May 09, 2014 8:08 pm
Custom trailer is coming together;
on this chassis;
but will replace the nasty lights and wheels with DeLorean ones (pending time & money).
Starglider
VIN #: 12306
Postby Starglider » Mon May 26, 2014 4:20 pm
More messing about with trailer bits as the DMC-12 is in the Netherlands at the moment.
Starglider
VIN #: 12306
Postby RobvdVeer » Mon May 26, 2014 5:34 pm
i like it
Postby Starglider » Sun Jun 01, 2014 4:35 pm
More progress on the 'useless trailer' as RobvdVeer named it ;) Got the base firmly attached to the chassis.
The scale of the new series design is quite substantial, especially since the DeLorean is so low. Will have to be careful driving in crosswinds.
Slight problem with the hubcentric spacers, that I'm using to fit DeLorean front wheels to the trailer. The center hole diameter is correct on the inside but there's a flange on the outside rim with a smaller inner diameter, that blocks the hub from coming through. Will have to angle grind it off.
Starglider
VIN #: 12306
