Project 3193
Re: Project 3193
Postby InoX » Sat Mar 27, 2010 10:39 am
headlight buckets are also with the powder coaters.
Re: Project 3193
Postby KMC-DMC » Sat Mar 27, 2010 4:46 pm
Will you be putting soundproof lining inside the car? I'm 'dynamting" my car bit by bit at the moment and it would be much better to this with the whole interior dismantled. DMCH do this to all their new builds....
Kevin
Kevin
KMC-DMC
Ex owner of VIN 2969
London
KMC-DMC
VIN #: Ex 2969
Re: Project 3193
Postby mnickels » Sat Mar 27, 2010 8:13 pm
KMC-DMC wrote:Will you be putting soundproof lining inside the car? I'm 'dynamting" my car bit by bit at the moment and it would be much better to this with the whole interior dismantled. DMCH do this to all their new builds....
Kevin
I'll be doing mine like that next winter hopefully
Re: Project 3193
Postby InoX » Sat Mar 27, 2010 9:18 pm
Kevin
Yep - once i get around to it. it's definitely one of the things I'll be doing.
Re: Project 3193
Postby InoX » Thu Apr 01, 2010 11:40 am
headlight bins and brackets, pedal box and windshield trim piece are back from the powdercoaters.
calipers back from the blasters.
I've also got hold of a pair of stainless hood brackets from Ed and a pair of steering shafts from a chap in SoCal (shafts only cost $90 for the pair and they're in excellent condition - bargin).
plenty to do.
Re: Project 3193
Postby InoX » Mon May 03, 2010 3:53 pm
not sure what the PO was trying to do here:
it's the diag plug ground wire connected to the ECU power wire...i think.
must be a record: four melted fuses. marvellous.
Re: Project 3193
Postby Admin-bloke » Mon May 03, 2010 4:03 pm
I have 4 melted ones too....
You might have started a new competition here !!!
Re: Project 3193
Postby InoX » Mon May 03, 2010 8:22 pm
looks like it's 1, 2 7 & 8.
7 i can understand as it's generally considered that most deloreans suffer from this fuse holder melting.
I guess the others perhaps melted because of the proximity in the box?
oh the joy.
No matter how much time i spend on this car nothing seems to get done...
Spent all weekend polishing scratches and scraping old sealant off the doors...
ADMIN bloke, do you think we could do a poll/survey getting our fellow Delorean chums to check their boxes? I'll give a packet of Fruit Polos to the person who has an original box but no melted number 7 (excludes the likes of 'Dusty' that only had 4 miles on it).
Re: Project 3193
Postby Chriss » Mon May 03, 2010 9:27 pm
InoX wrote:ADMIN bloke, do you think we could do a poll/survey getting our fellow Delorean chums to check their boxes? I'll give a packet of Fruit Polos to the person who has an original box but no melted number 7 (excludes the likes of 'Dusty' that only had 4 miles on it).
My old car was on the original fuse box and all the fuses were fine, there again I serviced the fuse / relays every so often :)
Re: Project 3193
Postby arranj » Mon May 03, 2010 9:46 pm
I have an original fuse box with 4 melted fuses. Plus an Admin-bloke® modification to bypass said fuses with non-fuse-box fuse holders 8-)
