MOT Help!!!
Re: MOT Help!!!
Postby Admin-bloke » Thu Aug 05, 2010 3:50 pm
frostrobo wrote:
Chriss wrote:Sunday 15th should be OK for me too.
So if Darren C has a spare, or failing that maybe Chris N? then a quick referb and swap 'tec' on the 15th? Hows that sound Simon?
That sounds great to me! I don't have much in the way of tools, but I have borrowed two ramps, a trolley jack and a small hydraulic jack etc. If people can give me a list of what would likely to be needed I can go and invest in some bits. If you guys think that a refurbished rack is the best option then lets go with that.
Thanks,
Simon
You will need a ball joint separator to remove the track rod ends from the hub assembly:
I have used the Scissor type removers for years and they don't destroy the rubber boot if used carefully.
Halfords web site, in search field type in:
Laser Ball Joint Separator Scissors
if the web link does not work:
http://www.halfords.com/webapp/wcs/stor ... yId_165469
For safety always use Axle stands if you do any work under the car. Safety First !
Re: MOT Help!!!
Postby Admin-bloke » Thu Aug 05, 2010 3:51 pm
Thanks,
Simon
Chances are you will have to get the car alignment (geometry) re-done afterwards.
Re: MOT Help!!!
Postby frostrobo » Fri Aug 06, 2010 1:57 pm
Trip to Halfords in order over the weekend for axle stands and seperators then!
frostrobo
VIN #: 4748
Re: MOT Help!!!
Postby hana 5284 » Fri Aug 06, 2010 9:02 pm
dmc4087 wrote:How can anyone own a DeLorean and not have a load of tools to back them up? :P
because we all have a wicked web site and fantastic members to fall back on ;) unlike more less fortunate clubs that dont have the club members behind them and great forum knowledge
Re: MOT Help!!!
Postby frostrobo » Sun Aug 08, 2010 11:19 pm
Hi,
Well I jacked up the car and had a quick look without getting uder the car... the wheel does have some play from the end of the rack, and there is a clonking noise from the joint if turn the wheel. There is not a huge amount of play though, and everything seems secure. I guess the rack is just a bit worn then. Axel stands and splitter will arrive this week, so will be set for the 15th if thats still ok? :)
Fixed number plate light.. without losing the metal screw plate down the back of the fascia :) I seem to have several loose connections on the car that only show themselves up at mot time. I checked that everything was working beforehand as well.
Simon
frostrobo
VIN #: 4748
Re: MOT Help!!!
Postby Chriss » Tue Aug 10, 2010 12:29 am
15th is fine. Trying to sort a replacement rack, might of found one but wont know until Wednesday / Thursday.
1981 DeLorean DMC12 VIN #6328
Re: MOT Help!!!
Postby frostrobo » Thu Aug 12, 2010 1:52 pm
Chriss wrote:15th is fine. Trying to sort a replacement rack, might of found one but wont know until Wednesday / Thursday.
That's great Chris.. lets hope it works out. Thanks for the recent email.
Simon
frostrobo
VIN #: 4748
Re: MOT Help!!!
Postby Admin-bloke » Thu Aug 12, 2010 5:17 pm
I won't be able to come and help but good luck and hope it goes smooth.
I will be on the end of a phone if you need telephone support :D
Postby Chriss » Thu Aug 12, 2010 5:17 pm
Not looking good for the replacement rack thanks to royal mail!
Still we can pull your rack off on Sunday and then can pop up one evening maybe next week to put it back.
You up for the Lunch at Arran's place in Norfolk after Simon?
Re: MOT Help!!!
Postby frostrobo » Fri Aug 13, 2010 1:58 pm
Darn that Royal Mail lol
Yes sure that would be good!
Yep I'll be up for lunch at Arrans' too.
frostrobo
VIN #: 4748
