VIN 4566 Restoration
Re: VIN 4566 Restoration
Postby MikeWard » Mon Apr 13, 2015 11:32 am
Re the DeLorean fuel tank, Chris Nicholson also has them if you get stuck.
BABIS wrote:Hello Mike, I've just seen the beautiful pictures of your interiors! are the rear speakers panels redyed or retrimmed? and the "A" pillars? any troubles in reinstalling them?
Best regards
A combination of both, the panels themselves were re-dyed, but the arm rests (bolsters) were re-trimmed.
The 'A' pillars are the only interior parts which were not removed from the car (on Lee's advice), Lee gave me some of the dye he had used on the interior pieces and I re-dyed the 'A' pillars in situ.
Postby Dan Willis » Mon Apr 13, 2015 2:57 pm
Good point. He has stacks of them, too.
I'm in no hurry anyway. I suspect the car will need to visit Chris (more than once) too.
VIN 4566
Ex VINs 5284, 5641
Dan Willis
VIN #: 4566
Postby MikeWard » Mon Apr 13, 2015 3:18 pm
Unless his pricing has changed, it will cost you about £10 :)
Postby Dan Willis » Mon Apr 13, 2015 4:15 pm
That's very reasonable!
VIN 4566
Ex VINs 5284, 5641
Dan Willis
VIN #: 4566
Postby Dan Willis » Sat Apr 18, 2015 6:06 pm
The sun was out today, and so it was time for the DeLorean to do the same. With recent work, she's been on axle stands for a while. Today, I dropped her down and wheeled her out for some work. Without brake calipers, she moved very smoothly (I just had to be careful I could stop the momentum!).
Outside:
ImageDelorean_work_180415_001 by willisit, on Flickr
ImageDeLorean work by willisit, on Flickr
Some interesting stuff today. First off, I have really only had access to one side. I got the passenger door open today and was going to replace the gas strut, but discovered this:
That'll be an expensive fix! Oh well, when she finally gets to have her cosmetics done, it'll be on the list for Chris to fix ;)
This door also had a piece of trim hanging off. But, by a screw and not a clip. I have no idea why people own these cars and feel it's easier to do this sort of thing, but since the interior is being retrimmed at some point, I guess it'll be okay.
Headliner off and more.. writing of sorts:
Some pics of the poorly interior. Very much sun-damaged, along with the smashed windscreen and broken rear-view mirror. Again, all known about and I'm not bothered much. It'll all get fixed/replaced as and when it's time to do so.
Today was, in fact, all about seeing if I could turn the engine. I took out the plugs, and disconnected what was left of the fuel system at the engine-end. Nothing worries me here, but most of the hoses are going in the bin - they are cracked or broken in places and there are few seals.
I popped off the leads and this one wasn't attached:
Luckily it's only the top:
The rest are okay but the tips are far from consistent. This'll be an interesting build:
Flickr has a ton of pics of plugs and rats nest wiring I need to look in to - feel free to browse.
But, attach a battery, I did:
A turn of the key and we had lights! All door lights worked, even the headlights and indicators. The wipers moved.. so all in all, it could have been worse. Then, of course, it was...
Without brakes, I used the gearbox to keep the car still. I turned the key and the bloody thing shot off! Turning off did nothing - the starter kept on going. Luckily I got it out of gear and got the battery disconnected - and when reconnected it was okay. Odd. Anyway, the engine turns quite happily (not exactly planned that way, but still).
There are electrical gremlins here - a starter that won't quit is an interesting one. It might be barrel, fuse or even relay related but I'm not looking in to that just yet.
A pretty constructive day all in. More dismantling to come as I've found a partner to get the frame off and stripped/re-coated, so it's going to be an interesting summer!
VIN 4566
Ex VINs 5284, 5641
Dan Willis
VIN #: 4566
Postby Dan Willis » Mon May 04, 2015 12:51 pm
More work:
Brakes are off for refurb or replacement:
Broken aerial is out too. It's knackered. Not entirely sure it's worth replacement, but I'll consider it nearer the completion:
Frame number (4778):
The engine is coming out soon and the entire exhaust system (such as it is) is going in the bin:
Accessible bottom :) :
More writing on the frame. Different the welded panel:
Part of the work over the weekend was removing all frame bolts. Pretty much all were hand tight. Not sure if that's normal (doubtful!):
I'm restricting myself to 2 hours a day on this. It keeps me interested and saves me waking up the next day feeling like I've been hit by a train. So, slow progress!
Anyway, I had to stop - garage work is starting Wednesday and the car has to sit on the lawn for three days, so I can't do any more without making it impossible to move. :)
VIN 4566
Ex VINs 5284, 5641
Dan Willis
VIN #: 4566
Postby A Van » Wed May 06, 2015 9:18 pm
Your making good progress, thanks for uploading
Postby astralflood » Sun May 31, 2015 10:50 pm
Can I ask how much you originally paid for the car? trying to get a rough idea on the amount of work needed on how much you spend for a Delorean?
astralflood
VIN #: not yet
Postby Biff » Mon Jun 01, 2015 2:43 pm
Good work fella.
Just out of interest are there any up-rated/later, more powerful, callipers that just bolt on or with adapters?
Biff
VIN #: 05127
Postby MikeWard » Mon Jun 01, 2015 3:08 pm
Biff wrote:Good work fella.
Get the original calipers refurbished (send them to Big Redd), fit a 50/50 bias master cylinder from a Saab 900, and EBS Redstuff pad's.
