Look what I've got back....
Re: Look what I've got back....
Postby jerzybondov » Thu Mar 30, 2017 3:11 pm
Fettling is one word for the wretched process that's involved getting anything to fit back anywhere on a Delorean after you've taken it off :D
Postby InoX » Thu Mar 30, 2017 3:39 pm
yep. plus when you're on your back, can't see a thing blind to the gap and clearance of the binnacle and the dash can make it very frustrating. Looks okay now though. Or about as good as I'm going to get it for an early vin interior where nothing fitted 36 years ago let alone now :D
Postby A Van » Thu Mar 30, 2017 9:52 pm
Looks good
A job I don't like is removing or refitting that....
Did you sort the lamps
Postby InoX » Fri Mar 31, 2017 8:32 am
no joy with the lamps. confident that it's an issue elsewhere. going to try and see what's going on over the weekend.
Take it the seat belt lamp needs the buzzer installed?
Postby InoX » Fri Mar 31, 2017 9:20 am
Success with the seatbelt lamp.
Just jumpered the yellow/purple and the black/purple at the buzzer connector and the seatbelt light comes on, then goes off when I put the seatbelt on. :dance:
The solution to the door ajar light must be obvious. It's a simple circuit and I think I'm missing it..... :violin:
Postby InoX » Sun Apr 02, 2017 1:52 pm
Quick update. Stalled refitting the interior bits while I wait on new fastners. Started to install silicone hoses onto the car. Heater matrix hoses are the worst. right behind the a/c accumulator. Again lots of fettling to get one of them in. Also dropped a bollock on the main return engine end return. Put a straight 10cm hose in, but think it should have a bend in it. As it is there's a constriction in the hose. Think I'll be better off with a 45 in there. See next weekend if I can at least get the new rad in. Pics next week.
Postby InoX » Sat Apr 15, 2017 10:25 am
Think I've done a whoopsie.
Went to replace my coolant hoses in the engine bay and I believe that I need to purchase the right hand side metal coolant pipe to fit the coolant hoses I have already bought because the thing is an early vin.....
http://www.deloreanclub.uk/catalogsearc ... /?q=108678
The hose from the tank to the current metal pipe is too short. :doh:
Postby arranj » Sat Apr 15, 2017 12:11 pm
I always thought the two versions of that metal pipe are basically the same....
Do you mean the 90 degree hose from the coolant tank isn't big enough to reach both the tank and the metal pipe?
How is your tank mounted? Which tank is it?
Postby InoX » Sat Apr 15, 2017 1:04 pm
Yep the 90 degree hose is a couple of inches too short. I can pull up the main pipe to where they're just touching. The header tank is a stainless one I think I got from hervey. Post pics tomorrow. Cheers.
Postby arranj » Sat Apr 15, 2017 2:00 pm
Yes, a few pics with a tape measure too, so I can compare to various other pipes and hoses here
